ohahaha
desktop electric fan
Front panel function description
Fan Control Button - Function Description
1.      First press
The left light of the fan control status light is always on
The two fans start at the same time , and the speed indicator will be displayed on the digital display tube.
Rotate the rightmost button to adjust the speed . Turn to the right to increase the speed and to the left to slow down.
2.      Press the second time
The right light of the fan control status light is always on
Natural wind mode , the fan runs for 2 seconds , stops for 1 second , the 2 fan wheels flow , and the speed indicator will be displayed on the digital display tube
3.      Press the third time
The left light of the fan control status light flashes
Only the left fan is started , the right fan is stopped , and the speed indicator will be displayed on the digital display tube.
4.      Press for the fourth time
The right light of the fan control status light flashes
Only the right fan is started , the left fan is stopped , and the speed indicator will be displayed on the digital display tube.
5.      Press for the fifth time
Pause the fan and reset the number of buttons to zero
6.      Long press
Each time you operate the speed adjustment and timing , it will be automatically saved after 5 seconds , and the settings will be read the next time you start it.
Timing control button - function description
1.      Press and hold for 0.5 seconds
Timing status light flashes
Enter the timing time setting , rotate the rightmost button to set , turn left to decrease time , turn right to increase time , the time value will be displayed on the digital tube display , time unit : minutes
Press the fan control button to exit the timer setting
2.      Short press once
Start or stop timer
The timer status light is always on , which means the timer is started . At this time, the remaining time will be displayed on the digital display tube.
The timer status light is off and the timer is not started.
When the timer reaches 0 , the fan will be paused.
Rear panel function description
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 02:41:20
