OvlueArDB
Lao Zheng's Newmax 65W gallium nitride charger shell DIY
Other notes:
1. Due to the irregular welding of typec small boards, some boards are crooked and must be corrected to ensure that they are aligned with the holes on the front panel.
2. Because the power supply board is too thin and has insufficient mechanical strength, some transformers are not flat and need to be repaired.
3. The primary bottom of the board power supply is insulated with PVC gaskets and fixed with Tianmu 702 glue. Do not use 703 glue, which is too soft.
4. The secondary part does not need to be insulated for low voltage. Apply Kraft 5204k thermally conductive silicone evenly, and then stick it inside the casing to ensure that the pins are not short-circuited and that the holes on the front panel are aligned. Otherwise, it will be too late if the silicone is solidified.
Just buy the AC seat from Uxin Electronics.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 09:42:56
