sigma
C3009912_Ethernet transceiver solution verification board based on CH392F chip
       The CH392F chip comes with 10M Ethernet media transmission layer (MAC) and physical layer (PHY), is fully compatible with IEEE802.3 protocol, and has built-in Ethernet protocol stack firmware such as IP, DHCP, ARP, ICMP, IGMP, UDP, and TCP. The single-chip computer system can easily communicate via the CH392 chip. Supports two communication interfaces: SPI interface or asynchronous serial port, which can be selected by configuring the SEL pin. The built-in pull-up of the SEL pin defaults to the asynchronous serial port mode. If the pull-down resistor R3 is welded, the SPI mode is selected. On-board 5V to 3.3V converter.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 21:12:08
