ohahaha
"Real" condenser microphone circuit board
Schematic source: https://www.instructables.com/True-Condenser-OPA-Mics/
The preamplifier part is the same as the large diaphragm pure op amp microphone (48V) . I integrated the polarization plate into one board.
I used this board to verify the homemade capacitor capsule, so I directly used the maximum polarization voltage. When R11=0, the polarization voltage is the highest 80V. The most common imitation K67/87, CK12 and other capsules generally have a polarization voltage of 60V. Using a higher polarization voltage will increase the sensitivity, but the frequency response curve will also change. If you need to lower the polarization voltage, do not solder R11 first, connect a potentiometer to H1, power on and test the voltage from the Pol_T pad to ground, adjust it to the target voltage, and then connect a resistor with a value similar to the potentiometer's resistance to R11. U2 is a Schmitt trigger, 4584/40106, etc. can be used.
Validation results:
The sensitivity of an externally polarized pure condenser microphone is indeed much higher, and it is better than an electret with the same large diaphragm. However, whether I DIY a pure capacitor or an electret, it is very easy to get damp in a Guangdong room with a humidity of 80%. If it is not put in a box, it will become very noisy overnight, but if I put it on the dehumidifier and blow it for a few minutes, it will stop It's completely better, and commercial condenser mics won't change that much. I'm not sure whether it's the microphone problem or the circuit board problem. Yesterday I bought PCB insulation paint to paint the circuit board to see if it can improve the problem.
Directions for improvement:
1. I use 1206 for R9R10 just because I don’t have the resistance value of 0805. OCD can replace it.
2. A group of friends reminded me that it is not recommended to use ordinary MLCC for the C6C7 on the front board. Using C0G or CBB capacitors can reduce noise.
3. I have a problem with the shielding hole on the input pin of the op amp. It is recommended to encrypt the shielding hole and thicken the wiring.
I am an amateur, and I have not learned many basic circuit knowledge comprehensively. If you have any other questions or suggestions for improvements in the project, please feel free to submit them.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 20:21:49
