sigma
Yufeng ESP_Mini remote control
The cool mini remote control controlled by ESP32 has two versions: basic version and upgraded Pro version. The basic version is open source.
The Pro version mainly improves the appearance and adds RGB joysticks, OLED screens, etc. At the same time, the power consumption increases by about 1/4, and the measured battery life is only a little over 1 hour. The basic version has a simple structure, fully modular design and longer battery life.
The information package contains reference programs for several supporting small projects. The receiving end includes ESP32 and ESP8266. There is a demo video address below.
Remote control introduction video address: https://www.bilibili.com/video/BV1nT4y1q7AD?spm_id_from=333.999.0.0
Other related project addresses: https://www.bilibili.com/video/BV1qT4y167JH?spm_id_from=333.999.0.0
                                 https://www.bilibili.com/video/BV1qu411r7dC?spm_id_from=333.999.0.0
                                 https://www.bilibili.com/video/BV1ha41177hL?spm_id_from=333.999.0.0
                                 https://www.bilibili.com/video/BV1nv4y1N7yB?spm_id_from=333.999.0.0
Materials:
1. PCB:
1. Bottom PCB*1;
2. Electronic control materials:
1. WEMOS D1 MINI ESP32*1;
2. High-precision 13*13 rocker potentiometer with cap*2; (If you buy an ordinary one The joystick will affect the control accuracy)
3. Bend-leg toggle switch*1 (3-pin 2-step spacing 2.54);
4. 8-bit WS2812B circular RGB module*1 (only to increase appearance, not required);
5. 3.7V Lithium battery (802035 model of 500mAh is the best)*1;
6, 6*6*5 silicone silent key switch*3;
7, Type-C female base 6P*1;
8, 6*6*6 horizontal tact switch *2 (You can choose a longer one);
9. CD42 charge and discharge module 5V2A*1 (note that there is a small hole on the side of this module on the PCB.
      You need to use a short wire or pin header to connect to the KEY on the module. This It is the on/off key that leads out, click to power on and double click to power off)
3. Other accessories materials:
1. 2.54 pin header 10P*4 for ESP32 main control board, 2.54 female header 10P*4;
2. 2.54 pin header curved pin 4P*1 for 8-bit RGB module;
3. 3D printed back Board*1;
4, M2*8 screws*4;
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:12:10
