黄土马家
YuzukiXR32F4 development board
Verifying...
About XR32F429
The XR32F429 is based on the high-performance ARM Cortex-M4F 32-bit RISC core clocked at up to 192MHz. The Cortex-M4F core has a floating point unit (FPU) single precision, which contains all ARM single precision data processing instructions and data types. It also implements a Memory Protection Unit (MPU) for application security. It supports integrated 832KB SRAM and 2MB flash ROM. It also includes many peripherals, including UART, TWI, SPI, I2S, DMIC, PWM, IrDA (T/R), CSI, SDIO, and auxiliary ADC.
Chip characteristics
  • Integrated high-performance ARM Cortex-M4F core and equipped with 832KB SRAM and 16Mbit Flash
  • Integrated hardware encryption and decryption engine to ensure the security of data transmission and storage
  • High integration, integrating UART, SPI, I2C, PWM, ADC, SDIO, IrDA, I2S, DMIC, CSI and other rich interfaces
platform
  • ARM Cortex-M4F core, up to 192MHz operating frequency
  • Built-in 832KB SRAM
  • Support low power consumption RTC mode
  • Integrated 2Kbit efuse
  • 6mm x 6mm 52pin QFN package
Encryption and decryption engine
  • Support AES ECB/CBC/CTR, 128/192/256-bit key
  • Support DES/3DES
  • Support MD5/SHA/SHA256/CRC16/CRC32/PRNG
peripherals
  • 2 channels SPI, 3 channels UART, 2 channels I2C, 1 channel SDIO, IrDA
  • 8-channel PWM, 8-channel ADC, several GPIOs
  • 1xI2S, 1xDMIC, 1xCSI
power supply
  • Single power input, wide voltage range 2.7V-5.5V support
  • Integrated 200mA 3.3VLDO, can be used to power peripherals
  • Built-in DC-DC and LDO for internal circuit use
  • Support low battery detection
  • Support system shutdown/wake-up from hibernation state
clock
  • 24MHz XTAL
  • 32768 low frequency clock
other
  • Working temperature -40~85℃, storage temperature -40~135℃
  • ESD HBM ±4000V, CDM ±800V
Rendering
Test chart
Pinout
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 22:40:10
