newrudeman
IP2322 5V input, dual series lithium battery/lithium-ion boost charging IC
USB power supply charger based on IP2322, suitable for charging 7.2V power tool batteries with battery capacity greater than 1125mah
 10W, 2A input synchronous switch boost charging
 Boost charging efficiency 90%
 Charging current external resistor is adjustable
 Automatically adjusts input current, matches all adapters
 Supports charging NTC temperature protection
 Supports LED charging status indication
 Built-in power MOS
 750KHz switching frequency, can support 2.2uH inductor
 Output over-current, over-voltage, short-circuit protection
 Input over-voltage, under-voltage protection
 IC over-temperature protection
 Charging timeout protection
 ESD 4KV
Introduction
IP2322 is a 5V input boost charging management IC that supports dual-cell series-connected lithium batteries/lithium-ion batteries.
IP2322 integrates power MOS and adopts a synchronous switching architecture, which requires only a few peripheral components during application, effectively reducing the size of the overall solution and reducing the BOM cost.
The IP2322 boost switching charging converter operates at a frequency of 750KHz; the maximum input charging is 2A, and the conversion efficiency is 90%.
The input voltage of IP2322 is 5V, and the input can intelligently adjust the charging current to prevent the adapter from being damaged.
IP2322 is available in DFN10 package.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 04:53:36
