aerobotics
High voltage differential probe
For discussion, please enter the Q group: 631060292. The original picture was drawn with eagle. Please check whether there are any conversion errors when making the board. TYPEC charging, battery protection, can also be used without batteries. Gain 500X measurement range 1200V30Mhz There are no overload detection, gear adjustment and other advanced functions. The negative 2.5V regulated voltage will not be stable when the battery level is lower than 30%. (Negative-voltage LDOs are too expensive, so try to use them with full power.) The current version has a large wiring parasitic capacitance and a relatively low bandwidth. It will be upgraded later to
install domestic gs8091 and other op amps and can also be used. The main picture is a direct measurement of 220V ACMeasuring switching power supply Vds
BOM download
Schematic_High Voltage Differential Probe_2022-10-08.pdf
SCH_High voltage differential probe_2022-10-08.json
High voltage differential probe_2022-10-08.zip
PCB_DP01_L01_2022-10-08.pdf
PCB_DP01_L01_2022-10-08.json
DP01_L01_2022-10-08.pcbdoc
Gerber_DP01_L01.zip
60869
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 16:38:11
