王达业
IV-27 fluorescent tube_L
 IV-27 fluorescent tube_left plate,
right plate and bottom plate link https://oshwhub.com/Wang233_CN/iv-27-ying-guang-guan
BOM download
PCB_PCB_IV-27 fluorescent tube_L_2022-09-25.pdf
PCB_PCB_IV-27 fluorescent tube_L_2022-09-25.json
PCB_IV-27 fluorescent tube_L_2022-09-25.pcbdoc
Gerber_PCB_IV-27 fluorescent tube_L_2022-09-25.zip
Schematic_IV-27 fluorescent tube_L_2022-09-25.pdf
SCH_IV-27 fluorescent tube_L_2022-09-25.json
Sheet_1_2022-09-25.schdoc
61202
ST-LINK V3 MOD adapter board
Introduction: STLINK-V3MOD adapter board
It has not been verified. When the board arrives, it will be verified again.
Two components need to be added to the original STLINK-V3MOD board. ST's ESD protection chip ESDALC6V1W5
BOM download
PCB_PCB_ST-LINK V3 MOD_2022-09-25.pdf
PCB_PCB_ST-LINK V3 MOD_2022-09-25.json
PCB_ST-LINK V3 MOD_2022-09-25.pcbdoc
Gerber_PCB_ST-LINK V3 MOD_2022-09-25.zip
Schematic_STLINK-V3MODS adapter board_2022-09-25.pdf
SCH_STLINK-V3MODS adapter board_2022-09-25.json
61203
hphphp
Introduction: Cross-thread the finished PCB with ropes or straps, pass a small wooden stick through the bottom hole, and the simple flowerpot is completed.
BOM download
PCB_NEW_PCB_2022-09-25.pdf
PCB_NEW_PCB_2022-09-25.json
NEW_PCB_2022-09-25.pcbdoc
Gerber_NEW_PCB_2022-09-25.zip
61204
Five-port Gigabit switch
Introduction: Based on the modification of Lichuang Open Source Project, it is modified to a typec DC dual power supply replacement power supply. If the middle port LED yellow and green wires are reversed, you can change them back by yourself. The proofing test is stable, based on RTL8367N-VB-CG
switch.pcbdoc
BOM download
Schematic_Five-port Gigabit switch_2022-09-25.pdf
SCH_Five-port Gigabit switch_2022-09-25.json
61205
Headlight LED charging control integrated TYPE-C
Introduction: The original circuit of the broken lamp does not have a charging chip and has been tested. If you need to pick it up, please don’t spray it.
BOM
Appearance.mp4
Charging current test.mp4
BOM download
PCB_PCB_Transfer_2022-09-25.pdf
PCB_PCB_Transfer_2022-09-25.json
PCB_transfer_2022-09-25.pcbdoc
Gerber_PCB_Transfer_2022-09-25.zip
Schematic_Headlight LED charging control integrated TYPE-C_2022-09-25.pdf
SCH_Headlight LED charging control integrated TYPE-C_2022-09-25.json
61206
USB-D to TYPE-C adapter board D port arduino
Introduction: USB-D to TYPE-C adapter board
BOM download
PCB_PCB_Adapter Board_2022-09-25.pdf
PCB_PCB_Adapter Board_2022-09-25.json
PCB_Adapter Board_2022-09-25.pcbdoc
Gerber_PCB_Adapter board_2022-09-25.zip
Schematic_USB-D to TYPE-C adapter board D port arduino_2022-09-25.pdf
SCH_USB-D to TYPE-C adapter board D port arduino_2022-09-25.json
61207
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 14:13:17
