张小哥
HDMI FPC flexible cable extension cable adapter
The line sequence uses the existing HDMI adapter line sequence on Taobao, the signal will be better, but because the drawing board capability is not enough, it is recommended that the fpc cable is as short as possible. I have only tested the 30cm fpc cable, and there is no longer one. test.
BOM download
PCB_HDMI_Type A_Male_2022-09-24.pdf
PCB_HDMI_Type A_Public_2022-09-24.json
HDMI_Type A_Male_2022-09-24.pcbdoc
Gerber_HDMI_Type A_Male_2022-09-24.zip
Schematic_HDMI FPC flexible cable extension cable adapter_2022-09-24.pdf
SCH_HDMI FPC flexible cable extension cable adapter_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61289
[Verified] Keyline separation TYPE-C USB HUB one to four
Introduction: usb 2.0 hub one-to-four crystal-free design, suitable for DIY
The frame hole position data uses the parameters in @dc65's open source project https://oshwhub.com/dc65/jian-xian-fen-li
The usb hub chip uses HS8836A, no crystal oscillator required, simple peripherals, and stable operation
BOM download
PCB_PCB_KEYboard hub_2022-09-24.pdf
PCB_PCB_KEYboard hub_2022-09-24.json
PCB_KEYboard hub_2022-09-24.pcbdoc
Gerber_PCB_KEYboard hub_2022-09-24.zip
Schematic_[Verified] Keyline separation TYPE-C USB HUB one to four_2022-09-24.pdf
SCH_[Verified] Keyline separation TYPE-C USB HUB one to four_2022-09-24.json
HS8836A_2022-09-24.schdoc
61290
Micro usb patch contact flying lead board
Introduction: Suitable for removing the micro usb female socket and replacing it with contacts that are easier to solder with flying wires. Inspired by @mz8023yz https://oshwhub.com/mz8023yt/Micro-USB-2-Type-C
The thickness of the board is 0.8mm. Because it is too small, I just "pieced it together" and just cut it by myself after the big board came out.
I didn't bring out the ID pin, mainly because I didn't need it and was just being lazy.
BOM download
PCB_Micro2C-pcb_2022-09-24.pdf
PCB_Micro2C-pcb_2022-09-24.json
Micro2C-pcb_2022-09-24.pcbdoc
Gerber_Micro2C-pcb_2022-09-24.zip
PCB_Micro2C-pcb 0.8mm copy_2022-09-24.pdf
PCB_Micro2C-pcb 0.8mm copy_2022-09-24.json
Micro2C-pcb 0.8mm copy_2022-09-24.pcbdoc
Gerber_Micro2C-pcb 0.8mm copy_2022-09-24.zip
Schematic_Micro usb SMD contact flying lead board_2022-09-24.pdf
SCH_Micro usb SMD contact flying lead board_2022-09-24.json
Micro usb patch contact flying lead board_2022-09-24.zip
61291
Verified USB HUB is based on SL2.1A one to four
Introduction: Based on SL2.1A USB2.0HUB, TYPE C input, four standard USB A female outputs, simple peripherals, only four capacitors and one crystal oscillator
# Based on the SL2.1A USB2.0 HUB
diode, you do not need to directly remove it, and then short-circuit or modify the PCB so that the power is directly input to the chip. SL2.1 has built-in LDO, and the surrounding capacitors are mainly used to filter the power supply and built-in LDO.
BOM download
PCB_sl2.1a_2022-09-24.pdf
PCB_sl2.1a_2022-09-24.json
sl2.1a_2022-09-24.pcbdoc
Gerber_sl2.1a_2022-09-24.zip
Schematic_Verified USB HUB based on SL2.1A one to four_2022-09-24.pdf
SCH_Verified USB HUB based on SL2.1A one to four_2022-09-24.json
61292
Power distribution
Introduction: pac/pdc dual power supply redundant backplane. The connector is limited to 28p + 20s, and is sold on Alibaba for 22 yuan (it actually uses a PCIE slot as the backplane of the pac3000s12, so it is not afraid of melting and sparking)
The base plate is suitable for the 2.5-inch hard drive bay of Lianli O11DMINI. Copper studs and copper screws are used to connect the upper and lower layers. The base plate needs to be welded with a 1MM thick copper strip. Please cut it by yourself.
BOM download
PCB_PCB_Power Distribution_2022-09-24.pdf
PCB_PCB_Power Distribution_2022-09-24.json
PCB_Power Distribution_2022-09-24.pcbdoc
Gerber_PCB_power distribution.zip
PCB_PAC_PDC power connection backplane_2022-09-24.pdf
PCB_PAC PDC power connection base plate_2022-09-24.json
PAC_PDC power connection base plate_2022-09-24.pcbdoc
Gerber_PAC_PDC power connection base plate_2022-09-24.zip
PCB_Border Test_2022-09-24.pdf
PCB_Border Test_2022-09-24.json
Border test_2022-09-24.pcbdoc
Gerber_border test_2022-09-24.zip
PCB_12-ATX upper layer_2022-09-24.pdf
PCB_12-ATX upper layer_2022-09-24.json
12-ATX upper layer_2022-09-24.pcbdoc
Gerber_12-ATX upper layer.zip
Schematic_Power Distribution_2022-09-24.pdf
SCH_power distribution_2022-09-24.json
61293
2 string lithium battery charge and discharge protection board
Introduction: Two string lithium battery charging protection board
Two string lithium battery charging protection board, using IP2322 chip
BOM download
PCB_PCB_2 string lithium battery charge and discharge protection board_2022-09-24.pdf
PCB_PCB_2 string lithium battery charge and discharge protection board_2022-09-24.json
PCB_2 string lithium battery charge and discharge protection board_2022-09-24.pcbdoc
Gerber_PCB_2 string lithium battery charge and discharge protection board_2022-09-24.zip
Schematic_2 string lithium battery charge and discharge protection board_2022-09-24.pdf
SCH_2 string lithium battery charge and discharge protection board_2022-09-24.json
61294
Nixie tube boost module
Introduction: MAX668EUB+
Boost module, boost from 5V to 170V
R2 and R3 resistor selection and output voltage calculation formula
BOM download
PCB_PCB_Nixie tube-1_2022-09-24.pdf
PCB_PCB_Nixie tube-1_2022-09-24.json
PCB_Nixie tube-1_2022-09-24.pcbdoc
Gerber_PCB_Nixie tube-1_2022-09-24.zip
Schematic_Nixie tube boost module_2022-09-24.pdf
SCH_Nixie tube boost module_2022-09-24.json
61295
IV-27M
Introduction: Fluorescent tube clock
Fluorescent tube model: iv27m
Project address: https://github.com/GourmetPowder/IV27M_Clock
BOM download
PCB_Connection_2022-09-24.pdf
PCB_Connection_2022-09-24.json
Connection_2022-09-24.pcbdoc
Gerber_connection_2022-09-24.zip
PCB_Left 1_2022-09-24.pdf
PCB_left1_2022-09-24.json
Left 1_2022-09-24.pcbdoc
Gerber_left1_2022-09-24.zip
PCB_right 2_2022-09-24.pdf
PCB_right 2_2022-09-24.json
Right 2_2022-09-24.pcbdoc
Gerber_right 2_2022-09-24.zip
PCB_Left 3_2022-09-24.pdf
PCB_left3_2022-09-24.json
Left 3_2022-09-24.pcbdoc
Gerber_left3_2022-09-24.zip
PCB_right 1_2022-09-24.pdf
PCB_right1_2022-09-24.json
Right1_2022-09-24.pcbdoc
Gerber_right1_2022-09-24.zip
PCB_Left 2_2022-09-24.pdf
PCB_left2_2022-09-24.json
Left 2_2022-09-24.pcbdoc
Gerber_left2.zip
PCB_IV-27M_2022-09-24.pdf
PCB_IV-27M_2022-09-24.json
IV-27M_2022-09-24.pcbdoc
Gerber_IV-27M.zip
Schematic_IV-27M_2022-09-24.pdf
SCH_IV-27M_2022-09-24.json
61296
Flowing water and ice
Introduction: The running water lamp Bingdundun made using 555 timer
Use 555 timer and CD4017BM to put a garland on Bingdundun
BOM download
61297
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 18:13:26
