XuwMD
【RA】Touch light bar based on Renesas RA2E1 microprocessor controller expansion
BOM download
PCB_Touch light strip board.Pcb_2022-09-24.pdf
PCB_Touch light strip board.Pcb_2022-09-24.json
Schematic_[RA] Touch light strip based on Renesas RA2E1 microprocessor controller expansion_2022-09-24.pdf
SCH_[RA] Touch light strip based on Renesas RA2E1 microprocessor controller expansion_2022-09-24.json
Light strip control panel.Sch_2022-09-24.schdoc
Touch light strip board.Pcb_2022-09-24.pcbdoc
Gerber_Touch light strip board.Pcb.zip
61309
Bluetooth power amplifier audio based on NS4251AB/D class power amplifier chip expansion
Introduction: Bluetooth amplifier audio based on NS4251AB/D class amplifier chip expansion
Battery management part:
       A multi-functional power management SOC using IP5306 voltage-to-voltage conversion, lithium battery charging management, and battery power indication. The conversion efficiency is as high as 92%. It can be expanded according to the simplified application provided in the data sheet. It can be powered by common Micro-B female sockets and type interfaces, or it can be powered by lithium batteries, making it easy to carry. The battery input range is 3.7V-4.2V.
      Update log: 2022/6/29, add dialing code The switch seat, battery rest base, and Bluetooth part seat can be facing inward, and you can see the LED covered by Bluetooth.
LV9sdQSToz31i8hOn9BRT8SmUnrhWIjRFukvjA6N.pngBluetooth module and audio input part:
   using MH-M18 Bluetooth The module supports the latest Bluetooth 4.2 transmission and two-channel stereo lossless playback. After the module is connected to Bluetooth, Bluetooth wireless transmission can be quickly realized, which is very convenient. In an open environment, the Bluetooth connection distance can reach 20 meters.
Bluetooth V4.2 version, supports Bluetooth automatic reconnection technology, supports WAV/WMA/FLAC/APE/MP3 lossless decoding, and stereo two-channel output.
After the module is powered on, the mobile phone searches for the Bluetooth name MH-M18/MH-M28/MH-M38, and music can be played after connecting to Bluetooth;
module blue indicator light:
when Bluetooth is not connected, the indicator light flashes quickly;
Bluetooth is connected When Bluetooth is playing, the indicator light is always on;
when Bluetooth is playing, the indicator light flashes slowly.
Pin diagram:
6YYjdENSJFT5gA2nQ5xjJsVvIucEd5DKZBSFRA9B.pngMain control part:
       Add a few capacitors to the audio input and Bluetooth input to filter interference to make the sound quality cleaner.
What you need to pay attention to are the several working modes of the main control chip:
wk71JVKus7IIb25sntD4cGlW2CLJMoWWAok95Kmc.pngStatus indicator light part:
       You can switch the working mode by referring to the data manual, and read the data manual carefully.
Demo video.mp4
IP5306.pdf
NS4251 data sheet.pdf
PCB_PCB_I love speakers_2022-09-24.pdf
PCB_PCB_I love speakers_2022-09-24.json
PCB_I love speakers_2022-09-24.pcbdoc
Gerber_PCB_I love speakers.zip
Schematic_Bluetooth power amplifier audio based on NS4251AB_Class D power amplifier chip expansion_2022-09-24.pdf
SCH_Bluetooth power amplifier sound based on NS4251AB Class D power amplifier chip expansion_2022-09-24.json
I love speakers.SCH_2022-09-24.schdoc
61310
Offline voice night light
Introduction: Offline voice night light based on Qiyingtailun C1122 main control design
Original link: https://oshwhub.com/course-examples/zhi-neng-jia-ju-zhi-nengai-yu-yin-xiao-ye-deng
      Schematic diagram:
ZWw2Pc7Ym825UO9ARF30GpVFTLjXZ4eOYDzy01fA.png       using typeC5V DC input for the module and four-way RGB The lantern is powered by the AMS11175 voltage regulator chip that converts to 3.3V stable DC output. 22uf and 10uf chip capacitors are added to both ends for filtering to ensure the stability of the medium input power supply. When choosing a model, it is recommended to choose a horizontal interface. Because the wrong model was selected, I did not pay attention to welding it when I bought it and later found that the interface was standing upright, which was inconvenient for power input.
      The module uses Qiyingtailun C1122 as the main control. The module has its own LDO output of 3.3V. One end of the resistor R3 is connected to the ninth pin, and one end is connected to the 3.3V pull-up generated by itself to enter the download mode. RXD and TXD are serial port downloads. , the four RBGs are driven by NPN type transistors. When the module outputs a high level, the transistors are turned on. By controlling the duty cycle and time of the PWM, the effect of colored lights can be modulated. The output speaker is 4W3Ω, which can be purchased on Taobao. Plus four copper post holes for easy fixing.
     PCB:
xs0vzWQcrSQJxPLjjZITxzbFPBRRKBTAkEJSOf0y.png     The layout places the four RBGs at the four corners, the microphone in the center, and the speaker interface on the right.
     Power supply part: In order to ensure the circulation of the power supply and the return of the ground, the power line should be more than 20 mils, and the GND should be connected with copper. The placement of vias will help the heat dissipation of the power supply and the return of the ground. Pay attention to the bottom of the module when laying copper. Do not lay copper to prevent signal interference. Logos and pictures added by yourself.
     For the code and software debugging part, please refer to the original link. Upload the above to the attachment.
Demo video.mp4
BOM_PCB_Offline Night Light_2022-03-20.csv
[Lichuang Classroom] Intelligent AI offline voice night light.pdf
Qiyingtailun-offline speech recognition chip-AI voice pet lamp development.pdf
Qiyingtailun-offline speech recognition chip-GPIO.pdf
Qiyingtailun-offline speech recognition chip-PWM.pdf
Qiyingtailun-offline speech recognition chip-serial protocol and LOG printing.pdf
BOM download
PCB_PCB_Offline Night Light_2022-09-24.pdf
PCB_PCB_Offline Night Light_2022-09-24.json
PCB_offline night light_2022-09-24.pcbdoc
Gerber_PCB_offline night light.zip
Schematic_Offline Voice Night Light_2022-09-24.pdf
SCH_Offline Voice Night Light_2022-09-24.json
Night light schematic diagram.SCH_2022-09-24.schdoc
61311
[Internet of Things] Hongmeng Smart WiFi Switch 985502A
Introduction: The wifi module developed based on HiSilicon HI3861 chip realizes the need to turn off the lights manually in the dormitory
Overall design block diagram
![image.png] ![image.png](https://image.lceda.cn/images/2022-1/60a95ddd36204044a43bc9a6c62a828a.png)
## Schematic design description
![image.png] Power supply The module uses the AMs117 voltage stabilizing module to provide a stable output voltage for the module. Due to the wrong model selection of the interface, the charging direction is vertical.
## PCB design description
![image.png]
## Software description
code attachment has been uploaded
## Physical display description
demonstration video has been uploaded
## logo verification
![image.png]
SD.mp4
Hongmeng switch.zip
BOM download
PCB_Smart WiFi switch.PCB_2022-09-24.pdf
PCB_Smart WiFi switch.PCB_2022-09-24.json
Smart WiFi switch.PCB_2022-09-24.pcbdoc
Gerber_Smart WiFi switch.PCB.zip
Schematic_[Internet of Things] Hongmeng Smart WiFi Switch 985502A_2022-09-24.pdf
SCH_[Internet of Things] Hongmeng Smart WiFi Switch 985502A_2022-09-24.json
Smart WiFi switch.SCH_2022-09-24.schdoc
61312
ESPC3-12F based training camp clock
Introduction: Training camp IoT clock based on Essence ESP-C3F-12F
BOM download
PCB_IoT Clock-PCb_2022-09-24.pdf
PCB_IoT clock-PCb_2022-09-24.json
IoT clock-PCb_2022-09-24.pcbdoc
Gerber_IoT clock-PCb.zip
Schematic_Training camp clock based on ESPC3-12F_2022-09-24.pdf
SCH_Training camp clock based on ESPC3-12F_2022-09-24.json
IoT clock-SCH_2022-09-24.schdoc
61313
bingDundun
Introduction: The Bingdundun Jump Squat
has been scaled and is now 5*5.7cm. The connection between the perforation and the main body of the board has been strengthened
. The board has been made. The effect is
only for learning. Do not use it for commercial purposes.
For educational purposes only, not for commercial use.
Bingdundun, one for each person, come quickly
BOM download
PCB_bdda.PcbDoc_2022-09-24.pdf
PCB_bdda.PcbDoc_2022-09-24.json
bdda.PcbDoc_2022-09-24.pcbdoc
Gerber_bdda.PcbDoc.zip
61314
AI infrared voice assistant
Introduction: AI infrared voice assistant developed based on zero code
BOM download
PCB_PCB_AI infrared voice assistant_2_2022-09-24.pdf
PCB_PCB_AI infrared voice assistant_2_2022-09-24.json
PCB_AI infrared voice assistant_2_2022-09-24.pcbdoc
Gerber_PCB_AI infrared voice assistant_2.zip
Schematic_AI infrared voice assistant_2022-09-24.pdf
SCH_AI infrared voice assistant_2022-09-24.json
AI infrared voice assistant, Sch_2022-09-24.schdoc
61315
【Training Camp】A dog leg
Introduction: I made a little cheap clock, but the acrylic cut shell was broken by me and could not be fixed. The new 3D printing is still on the way. The video I shot is just for moving it.
I made a little cheap clock, but the acrylic cut shell was broken by me and couldn't be fixed. The new 3D printing is still on the way. The video I shot is just for moving it.IMG_20220720_014216.jpg
petal_20220720_011227.mp4
PCB_PCB1_2022-11-05.pdf
BOM_Board1_PCB1_2022-11-05.xlsx
Altium_[Training Camp] A dog leg_2022-11-05.zip
PDF_[Training Camp] A dog leg_2022-11-05.zip
BOM_Board1_[Training Camp] A dog leg_2022-11-05.xlsx
61316
running water rotating light
Introduction: The picture was intercepted from station B. Please don’t blame the copyright infringement for deletion. The lights light up like rotating energy. I plan to make a similar one.
The STC8G1K08A microcontroller writes a horse racing program with 5 to 8 legs. It only knows four legs. The effect of lighting up exactly 8 LED lights is better, but the painting is too ugly. . . Can anyone plan a route?
BOM download
PCB_PCB_marquee_2022-09-24.pdf
PCB_PCB_marquee_2022-09-24.json
PCB_Marquee_2022-09-24.pcbdoc
Gerber_PCB_marquee.zip
Schematic_Flowing water rotating light_2022-09-24.pdf
SCH_Flowing water rotating light_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61317
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 13:13:30
  • Manual soldering techniques for SMD components
  • Converting power supply issues
  • Two microcontrollers communicate via serial port
  • XILINX SPARTAN 3E和VIRTEX II PRO
  • 2006 Hubei Province Electronic Design Competition Topic: Intelligent Transporter
  • msp430F149 ADC issue
