念慈菴
5th order light cube-10cm
A fifth-order light cube with a size of 10*10*10cm can be produced in one go.
This is the second version. The first version is here: 5X5X5 Light Cube - Jialichuang EDA open source hardware platform (oshwhub.com)
Actual video: 5th order light cube second version PCB, the design is a bit flawed, but it can still be used_beep bilibili_Comparison
of two versions of bilibili: Two fifth-order light cubes, double happiness_bilibili_bilibili
open source video has not been made yet: Electronic Studio-'s personal space_bilibili_bilibili
second version Compared with the first version,
1, the size has been increased, it is also 5th order, the size is larger, and the effect from a distance is better.
2, the number of capacitors has been reduced, and 2 capacitors per layer are enough.
3. The layer connection positions have changed. They were staggered before, but now they are put together, with less obstruction.
4. There is one missing pillar support. The position of the pillar is replaced by layered pin headers and female headers. This is not acceptable to everyone. It does not look very symmetrical. If you have obsessive-compulsive disorder, I suggest you change it yourself.
Although it looks ugly, the structure is still very stable and will not deform without using force.
5. The pad area is increased, making it easier to solder. Of course, it is the same if it is a teppanyaki.
PCB proofing can be done directly at JLC ​​for 0 yuan. Then it is recommended that the color is black and the board thickness is 1.2mm.
Component purchase: [Tencent Document] Electronic Studio Sharing Form https://docs.qq.com/sheet/DYm1tTUFlRWhkQVJt
The light cube components have been updated in the form. Please check it yourself. As for the components For quantity, you can check the BOM and watch the video.
Program code: No, write it yourself. WS2812 is too common.
The text content has ended, next is a multi-picture display:
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-02 20:27:43
