aerobotics
Universal dot screen PCB design
Physical display, principle explanation, and illuminated examples: Where did the video go? _bilibili_
Some of the screens on bilibili have non-integer screen spacing of 0.1mm, so they are temporarily unavailable. The current board is already 10*10cm.
The reason for designing this board: I often pick up junk screens and must light them up for verification. Using DuPont wires is laborious and unstable, so I designed this board.
The PCB of this board has 4 layers, and there are many components and vias, so The standard version of Lichuang EDA is a bit unbearable, and it would be better to use the professional version.
The current design is very intensive in order to be compatible with the 16-bit parallel port. There is no way around this. In fact, it is enough to be compatible with the 8-bit parallel port.
The main control is STC8 series. Generally, STC8H1K17-TSSOP20 is sufficient for the screen.
If it is a 16-bit parallel port, use STC8H1K28-LQFP32
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-04 14:40:00
