ohahaha
CH32V103C8T6
The main control is Nanjing Qinheng's CH32V103C8T6, maximum 80MHz, onboard ADXL335 analog acceleration sensor, MPU6050 IIC communication acceleration sensor, SHT30 temperature and humidity sensor, 0.66OLED, 1.14 plug-in LCD interface.
BOM download
PCB_PCB_CH32V1023C8T6_2022-09-24.pdf
PCB_PCB_CH32V1023C8T6_2022-09-24.json
PCB_CH32V1023C8T6_2022-09-24.pcbdoc
Gerber_PCB_CH32V1023C8T6.zip
Schematic_CH32V103C8T6_2022-09-24.pdf
SCH_CH32V103C8T6_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61379
STM32G031G8U6
Introduction: STM32G031G8U6 development board
STM32G031G8U6 development board, G031 is currently one of the cheapest ST single-chip models. Its performance is also good, and it is also good for small development. There is an SGP30 TVOC/CO2 sensor on the board, a CH340E and a passive buzzer. One user button and 2 LEDs, and the remaining IO ports are led out.
G031 FULL-FUNCTION.zip
BOM download
PCB_PCB_G031_2022-09-24.pdf
PCB_PCB_G031_2022-09-24.json
PCB_G031_2022-09-24.pcbdoc
Gerber_PCB_G031.zip
Schematic_STM32G031G8U6_2022-09-24.pdf
SCH_STM32G031G8U6_2022-09-24.json
61380
STM32G070RBT6 primary board
Introduction: STM32G070RBT6 development board, onboard DAP downloader
STM32G070RBT6 development board, onboard DAP downloader (using CH32F103C8T6). The board integrates an active buzzer, infrared receiver and transmitter, DS18B20 temperature sensor, AHT20 temperature and humidity sensor, adjustable resistor (ADC), 4-digit digital tube, 0.91 OLED screen, W25Q80, 24C02 and SD card holder (SPI Way). The problem of flying wires at the OLED cable arrangement has been fixed. DAP firmware address: https://github.com/wuxx/nanoDAP Thanks to Muse Lab
BOM download
PCB_PCB_STM32G070RBT6 Primary Board_2022-09-24.pdf
PCB_PCB_STM32G070RBT6 primary board_2022-09-24.json
PCB_STM32G070RBT6 primary board_2022-09-24.pcbdoc
Gerber_PCB_STM32G070RBT6 primary board.zip
Schematic_STM32G070RBT6 primary board_2022-09-24.pdf
SCH_STM32G070RBT6 primary board_2022-09-24.json
61381
STM32F411CEU6 BLUE-TOOTH
Introduction: STM32F411CEU6 Development Board
The main control uses STM32F411CEU6, and ST-Link V2.1 is onboard for easy debugging. In terms of communication, there are ECB02S3 Bluetooth module from Yijia IoT and Nanjing Qinheng’s CH9120 Ethernet to serial port chip. The storage uses W25Q256 SPI FLASH chip and BL24C64 EEPROM chip, and also has an SD card holder (SDIO). The sensors include BMP280 (can be replaced by Pin-to-Pin by SPL06-001) and SHTC3. In addition, there is a VS1035B audio chip with a 3.5mm headphone jack and a Zhongjingyuan 1.06LCD screen (GC9107)
BOM download
PCB_PCB_STM32F411CEU6 BLUE-TOOTH_2022-09-24.pdf
PCB_PCB_STM32F411CEU6 BLUE-TOOTH_2022-09-24.json
PCB_STM32F411CEU6 BLUE-TOOTH_2022-09-24.pcbdoc
Gerber_PCB_STM32F411CEU6 BLUE-TOOTH.zip
Schematic_STM32F411CEU6 BLUE-TOOTH_2022-09-24.pdf
SCH_STM32F411CEU6 BLUE-TOOTH_2022-09-24.json
61382
【Training Camp】Little Cheap Mini
Introduction: Little bitch, he has big dreams
It has to be said that it is very difficult to be a little bitch. The software is a nightmare. There is not much teaching, so I have to teach you step by step. . . . .IMG_2896.JPG
B52CC32B934464AFA21B1896F0063A62.MP4
BOM download
PCB_PCB_[Training Camp] Xiaojian mini_2022-09-24.pdf
PCB_PCB_[Training Camp] Xiaojian mini_2022-09-24.json
PCB_[Training Camp] Xiaojian mini_2022-09-24.pcbdoc
Gerber_PCB_[Training Camp] Xiaojian mini.zip
Schematic_[Training Camp] Xiaojian mini_2022-09-24.pdf
SCH_[Training Camp] Xiaojian mini_2022-09-24.json
omslittle bitch_2022-09-24.schdoc
61383
klipper oled screen adapter board
Introduction: The useless klipperOLED small screen has been verified on mks Monster 8. In theory, it can be used on all mks motherboards.
It's just for fun, it's poorly made, not very useful, the pictures are nice,
klipper doesn't seem to be able to mount the SD card through spi, it seems (does anyone know?)
#MKS-Monster8 0.96oled
[display]lcd_type: ssd1306cs_pin: PE9dc_pin : PE8reset_pin: PB11contrast: 255vcomh:63invert: Falseencoder_pins: ^PD9,^PE11click_pin: ^PE15spi_software_miso_pin: PA6spi_software_mosi_pin: PA7spi_software_sclk_pin: PA5
#mks genl2.1 (not tested)
[display]lcd_type: ssd13 06cs_pin: PC6dc_pin: PC4reset_pin: PL0contrast: 255vcomh:63invert : Falseencoder_pins: ^PA1, ^PH0click_pin: ^PC2#spi_bus: spispi_software_miso_pin: PB3spi_software_mosi_pin: PB2spi_software_sclk_pin: PB1
BOM download
PCB_PCB_klipper oled screen adapter board_2022-09-24.pdf
PCB_PCB_klipper oled screen adapter board_2022-09-24.json
PCB_klipper oled screen adapter board_2022-09-24.pcbdoc
Gerber_PCB_klipper oled screen adapter board_2022-09-24.zip
Schematic_klipper oled screen adapter board_2022-09-24.pdf
SCH_klipper oled screen adapter board_2022-09-24.json
61384
CH32V103C8T6 football
Introduction: Second Prize in the 2022 Electrical and Electronic Breathing Lamp Design Competition of the School of Electrical Engineering of Guangzhou City Polytechnic Institute
football
WeChat_20220608201748.mp4
code.zip
BOM download
PCB_PCB_DI2B copy_2022-09-24.pdf
PCB_PCB_DI2B copy_2022-09-24.json
PCB_DI2B copy_2022-09-24.pcbdoc
Gerber_PCB_DI2B copy.zip
PCB_PCB_DI2B_2022-09-24.pdf
PCB_PCB_DI2B_2022-09-24.json
PCB_DI2B_2022-09-24.pcbdoc
Gerber_PCB_DI2B.zip
Schematic_CH32V103C8T6 football_2022-09-24.pdf
SCH_CH32V103C8T6 football_2022-09-24.json
Sheet_2_2022-09-24.schdoc
61385
【Internet of Things】Smart WiFi switch
Introduction: Use Hongmeng Hi3861 chip combined with a servo to realize WIFI remote control of physical switches at home or dormitory
Use Hongmeng Hi3861 chip combined with a servo to achieve WIFI remote control of physical switches at home or dormitory
VID_20220407_214525.mp4
BOM download
PCB_PCB_[Internet of Things] Smart WiFi Switch_2_2022-09-24.pdf
PCB_PCB_[Internet of Things] Smart WiFi Switch_2_2022-09-24.json
PCB_[Internet of Things] Smart WiFi Switch_2_2022-09-24.pcbdoc
Gerber_PCB_[Internet of Things] Smart WiFi Switch_2.zip
Schematic_[Internet of Things] Smart WiFi Switch_2022-09-24.pdf
SCH_[Internet of Things] Smart WiFi Switch_2022-09-24.json
Schematic_2022-09-24.schdoc
61386
LOBSTER-3D printed motherboard
Introduction: Low-cost 3D printing motherboard based on STM32F103C6T6, only supports KLIPPER firmware
This project is redesigned for the APK2.1 motherboard. Thanks to the original author for open source.
Compared with the original version, it adds optocoupler/MOS isolation and anti-reverse connection protection.
The main control uses STM32F103C6T6, the price is extremely low, and the pins are compatible with C8T6 and F303 series.
5v uses ry9320/8310. The power supply solution is small in size, simple in peripherals and low in cost.
The me6118 provides a 3.3v power supply, which is a perfect replacement for the 1117
motor driver and provides a separate power supply to improve stability.
The expansion board interface is replaced with an XT30+PH2.0 cable arrangement. Loading capacity and stability
The motherboard provides three temperature probes (one is onboard thermal), four controllable fans, and one lighting interface.
The expansion board will support 8-axis printers and is suitable for voron2.4 printers.
Expansion board link: LOBSTER -3D printing motherboard - eight-axis expansion board - Jialichuang EDA open source hardware platform (oshwhub.com)
Chinese name is "Lobster".
The auxiliary welding file
github link is provided in the attachment: github.com/XMU-ZC/LOBSTER
The motherboard is currently the first version of the test board. Although it has been checked several times, there is still a possibility of design defects.
It is only for those who are interested in trying it out. If the test board is damaged due to possible circuit defects, please be responsible for it.
Friends who are willing to take the trouble should wait for the official version of the motherboard to be released .
STM32_LOBSTER-KLIPPER_V1.0beta_iBOM.html
Gerber_STM32_LOBSTER-KLIPPER_V1.0beta.zip
BOM download
PCB_STM32_LOBSTER-KLIPPER_V1.0beta_2022-09-24.pdf
PCB_STM32_LOBSTER-KLIPPER_V1.0beta_2022-09-24.json
STM32_LOBSTER-KLIPPER_V1.0beta_2022-09-24.pcbdoc
Schematic_LOBSTER-3D printing motherboard_2022-09-24.pdf
SCH_LOBSTER-3D printed motherboard_2022-09-24.json
61387
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 08:40:38
