Iru7vdqAH3
stupid Pi STM32G070 development board V1.0
Disclaimer
Thank you for using our Creative Commons work, which is licensed under the CC BY-NC-SA 3.0 license. Please read the following disclaimer carefully before using our work:
1. Accuracy and Completeness: We do not guarantee the accuracy and completeness of the work. Use of this work is at the user's risk.
2. Modification of the work: If you modify this work, you need to comply with the CC BY-NC-SA 3.0 license agreement and attribute it to the original author where appropriate.
3. Does not constitute advice: This work is only for information transmission and does not constitute any suggestions or opinions. Any user's decision to use this work should be based on their own judgment and risk.
4. Incidental losses: We are not responsible for any direct, indirect, incidental, special or incidental losses arising out of the use or inability to use this work.
Usage Notice
1. Intellectual Property Protection: Our Creative Commons works contain copyright protection, although the works are free for everyone to use. Your use of this work should comply with the applicable CC BY-NC-SA 3.0 license. Unless we indicate otherwise, this work is protected by copyright and may not be used or redistributed in any form without permission.
2. Non-commercial use: You may not use this work for commercial purposes. You may obtain permission for commercial use through other means.
3. Share Alike: You can share, distribute and use this work freely, but during the sharing process, you must comply with the CC BY-NC-SA 3.0 license agreement and indicate the original author and resource citation.
In conclusion, this disclaimer and usage notice are intended to protect us and the users who exploit our works. If you use this work, it means that you have read in detail and agree to this statement and notification. If you have any questions, please contact us.
______________________________________________________________________________________________________________________________________________________________
Physical picture
Regarding
the onboard 3.3V output, SY8089AAAC is used as the 3.3V output 5V. It is directly connected to USB. Please be careful not to short-circuit and cause damage to the USB interface when using it.
The project has been verified and will be uploaded later.
Onboard USB type-c only Serial port debugging has not been added for power supply. Only SWD debugging can be used.
In fact, I personally think that it is more convenient to use STLINK debugging, so the USB serial port example is not added. EVG253X63-300UA display module blink animation example project package name EPC-INBM32VL200CA_FirmWare
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 20:53:25
