containsmachine
IC card
Campus card, NFC PCB card, no problem in actual test, can light up by adding LED, current limiting resistor 1k
BOM download
PCB_PCB_IC Card 1_2022-09-24.pdf
PCB_PCB_IC Card 1_2022-09-24.json
61413
Rhythm beacon music level light
Introduction: Music level light with full analog circuit, music level light with full analog circuit, named Rhythm Lighthouse!
Full analog circuit music level light, full analog circuit music level light, named Rhythm Lighthouse! The effect is very good, the sensitivity is adjustable, the light board is in the accessory and is a flat light, named Rhythm Lighthouse! Some bugs have been fixed
VID_20220819_201827.mp4
lighthouse.json
BOM download
PCB_NEW_PCB_2022-09-24.pdf
PCB_NEW_PCB_2022-09-24.json
NEW_PCB_2022-09-24.pcbdoc
Gerber_NEW_PCB.zip
Schematic_Rhythm Lighthouse Music Level Light_2022-09-24.pdf
SCH_Rhythm Lighthouse Music Level Light_2022-09-24.json
Base_2022-09-24.schdoc
61414
M18 Bluetooth module adapter board
Introduction: M18 Bluetooth module adapter board, Bluetooth music receiver
Connect the M18 Bluetooth module, draw out the button, add the charging module, battery power supply, no noise
BOM download
PCB_PCB_M18 Bluetooth module adapter board_2022-09-24.pdf
PCB_PCB_M18 Bluetooth module adapter board_2022-09-24.json
PCB_M18 Bluetooth module adapter board_2022-09-24.pcbdoc
Gerber_PCB_M18 Bluetooth module adapter board.zip
Schematic_M18 Bluetooth module adapter board_2022-09-24.pdf
SCH_M18 Bluetooth module adapter board_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61415
Sound simulation acquisition module, microphone module
Introduction: A pure discrete component sound collection module that outputs analog signals and can be used with another level light module of mine. The effect is very good.
A pure discrete component sound collection module that outputs analog signals and can be used with another level light module of mine. The effect is very good. Watch the video.
999146E02E25ACD8AA52BE9735729805.mp4
Level module.json
BOM download
PCB_PCB sound simulation collection_2022-09-24.pdf
PCB_PCB sound simulation collection_2022-09-24.json
PCB sound simulation collection_2022-09-24.pcbdoc
Gerber_PCB sound simulation collection.zip
Schematic_sound simulation acquisition module, microphone module_2022-09-24.pdf
SCH_sound simulation acquisition module, microphone module_2022-09-24.json
61416
Adjustable bright flashlight
Introduction: 12-watt strong flashlight, using pure hardware design mos tube linear dimming, 4 3-watt lamp beads, 15-degree lens manual strobe, capable friends can add a ne555 chip to automatically strobe, this is the suggestion of netizens , I’m going to work on the next project!
The tp4056x chip charges the lithium battery, and the MOS tube is controlled by an adjustable resistor to achieve dimming. The light board needs to add a heat sink, and it is best to add a fan!
Share the lamp bead link below the lamp board file
- [Taobao] Lens link - [Taobao]
PCB_led light board_.json
BOM download
PCB_PCB_Flashlight Main Control Board_2022-09-24.pdf
PCB_PCB_Flashlight Main Control Board_2022-09-24.json
PCB_Flashlight Main Control Board_2022-09-24.pcbdoc
Gerber_PCB_Flashlight main control board.zip
Schematic_Adjustable Highlight Flashlight_2022-09-24.pdf
SCH_Adjustable strong light flashlight_2022-09-24.json
61417
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 20:13:52
