太白金星
3D printer WiFi SD card large card 8266
Salted Fish has finished products for sale, please support the original creation! The WIFI SD card used by
Electronics Enthusiast Z 3D printer has passed the test on the large card. Please feel free to use it with the board. There is no way to test it on the small board. I hope someone can help with the test! Join the penguin group to communicate at 1104095430 (changed the group number! This is my group owner). I will send another firmware for everyone to test together! (I haven’t figured out the new firmware yet! I’ll post a detailed tutorial when it’s ready!) ESP3D firmware is supported, but the printer motherboard system needs to be version 2.0 or above! I haven't tested it successfully, you can test it yourself! Only printers with Marlin firmware can be used! There are printers that have been tested, but Xiaoshu does not work! Not tested with other printers!
BOM download
PCB_PCB_3D Printer SD Card Extension Second Edition copy_2022-09-24.pdf
PCB_PCB_3D Printer SD Card Extension Second Edition copy_2022-09-24.json
PCB_3D Printer SD Card Extension Second Edition copy_2022-09-24.pcbdoc
Gerber_PCB_3D Printer SD Card Extension Second Edition copy_2022-09-24.zip
Schematic_3D printer WiFi SD card large card 8266_2022-09-24.pdf
SCH_3D printer WiFi SD card large card 8266_2022-09-24.json
Sheet_1 copy_2022-09-24.schdoc
61511
STM32F103Z_BGA core board
Introduction: STM32F103Z_BGA package core board
============ Put ​​the important words first ==============
1. At present, it is only welding test, not all functions are tested (will test again after the holiday) ,
     1. The LCD data line is not sure whether there is a serial signal (it has been tested and there is a picture below)
     2. The SD card data line is not sure whether there is a serial signal
     3. The pin numbers are marked on both sides of the LCD, but the LCD is plugged in from the back (to prevent the gear pins) (picture below)
     4. Do not buy the original parts according to the BOM list, which may not be allowed
. 2. Soldering
     1. The stm32f103z in the BGA package is used (the new one is about 30 RMB)
     2. Although it is BGA, this is what I It doesn't feel like it's difficult to weld, you
can do it according to your ability.
stm32f103z should be familiar to everyone and I won’t say much =-=
===============BGA welding======== =========
You should all have an air gun and the like.
If you want to plant balls, scrape solder paste or something. Go to B station to find a video.
The temperature should not be too high. The steel mesh cannot stand
the flux. It is a necessity.
(I am too lazy to write emm when I have time)
================IO distribution================
     IO distribution It’s quite concentrated, don’t distract
     from the rest. You can read it by yourself =-= I was too lazy to write a description of
IO1          the LCD slot when viewed from the front and
lcd1            the LCD slot when viewed from the back
=================LCD============ =====
ps The control address used here is A6 (the Atomic F4 uses A6),
so when using the LCD screen, you need to change #define LCD_BASE ((u32)(0x6C000000 | 0x000007FE)) to #define LCD_BASE ((u32 )(0x6C000000 | 0x0000007E))
================ Attached Pictures ==================
That's it (I'm lazy).
This design uses 103 in bga package (yes This is the difference)
BOM download
PCB_STM32F103Z_2022-09-24.pdf
PCB_STM32F103Z_2022-09-24.json
STM32F103Z_2022-09-24.pcbdoc
Gerber_STM32F103Z.zip
Schematic_STM32F103Z_BGA core board_2022-09-24.pdf
SCH_STM32F103Z_BGA core board_2022-09-24.json
STM32F103ZE_2022-09-24.schdoc
61512
ETA3000+BM3451 lithium battery protection balance
Introduction: BM3451 battery protection + ETA3000 active balancing board, to be verified. The size of the board is 17cm*65cm, which is very small. It is necessary to verify the heat dissipation performance of the board and whether there is any conflict in the shutdown of charging between the two chips.
61513
Automatic winding machine based on Mega2560 and TB6600
Introduction: This is a project to automatically wind the electronic rotor. The microcontroller solution is arduino mega2560. The motor drive solution is Toshiba's TB6600, and the alternative solution is Trinamic's MTC2160.
This is a project for automatic winding of electronic rotors. The microcontroller solution is arduino mega2560, and the motor drive solution is Toshiba's TB6600
BOM_Atmega2560 microcontroller_Mega2560_2022-11-05.xlsx
Altium_Automatic winding machine based on Mega2560 and TB6600_2022-11-05.zip
PCB_Mega2560_2022-11-05.pdf
PDF_Automatic winding machine based on Mega2560 and TB6600_2022-11-05.zip
61514
Tactile Rubik's Cube and Pulse Summary
Introduction: Read the piezoresistive sensor signal, amplify it, and communicate using Bluetooth
The function of the DIP switch is to switch who is connected to the microcontroller, external serial port and Bluetooth.
BOM download
PCB_PCB_Tactile Rubik's Cube and Pulsation Summary_2_2022-09-24.pdf
PCB_PCB_Tactile Rubik's Cube and Pulse Summary_2_2022-09-24.json
PCB_Tactile Rubik's Cube and Pulsation Summary_2_2022-09-24.pcbdoc
Gerber_PCB_Tactile Rubik's Cube and Pulse Summary_2_2022-09-24.zip
PCB_Interface Board_2022-09-24.pdf
PCB_interface board_2022-09-24.json
Interface board_2022-09-24.pcbdoc
Gerber_interface board.zip
Schematic_Tactile Rubik's Cube and Pulsation Summary_2022-09-24.pdf
SCH_Touch Rubik's Cube and Pulse Summary_2022-09-24.json
Summary of touch cube and pulsation_2022-09-24.zip
61516
stm32 motor driver
Introduction: stm32 motor driver
1. The RS485 interface is designed to meet the lightning protection test requirements of IEC61000-4-5 or GB17626.5 standards, common mode 6KV, differential mode 2KV. D4 is a three-terminal gas discharge tube that forms the first-level protection circuit to suppress the line. Common mode and differential mode surge interference to prevent interference from affecting the next stage circuit through the signal line. The nominal voltage VBRW of the gas discharge tube is required to be greater than 13V, and the peak current IPP is required to be greater than or equal to 143A. The peak power WPP is required to be greater than or equal to 1859WPTC1 and PTC2 are thermal sensitive The resistor forms the second-level protection circuit. The typical value is 10Ω/2W. To ensure that the gas discharge tube can conduct smoothly, this resistor must be added to divide the large energy to ensure that most of the energy goes through the gas discharge tube D1~D3. It forms a third-level protection circuit for TSS tubes (semiconductor discharge tubes). The nominal voltage VBRW of TSS tubes is required to be greater than 8V, the peak current IPP is required to be greater than or equal to 143A; the peak power WPP is required to be greater than or equal to 1144W;
2.1.TIP32C is a high-power PNP Type transistor, UCEO=100V, IC=3A (continuous) or 5A (peak), power dissipation PD=40W; L7805 realizes 5V voltage regulation;
3.GC8871/DRV8871 brushed DC motor driver chip with internal current sensing function , suitable for printers, electrical appliances, industrial equipment and other small machines. Two logic inputs control the H-bridge driver, which consists of four NMOSs and is capable of bidirectional motor control at peak currents up to 3.6A. Current decay mode allows the motor speed to be controlled by pulse width modulation (PWM) of the input. If both inputs are driven low, the motor driver will enter a low-power sleep mode.
PCB_stm32 motor driver.json
BOM download
Schematic_stm32 motor driver_2022-09-24.pdf
SCH_stm32 motor driver_2022-09-24.json
stm32 motor driver_2022-09-24.zip
61517
[Internet of Things] Hongmeng Internet of Things—Smart WiFi switch
Introduction: IoT smart WiFi switch based on Hongmeng system
7E5C7398-DBEF-4CEB-8904-1B394C0A58D7.mp4
BOM download
PCB_PCB_[Internet of Things] Hongmeng Internet of Things—Smart WiFi Switch_3_2022-09-24.pdf
PCB_PCB_[Internet of Things] Hongmeng Internet of Things—Smart WiFi Switch_3_2022-09-24.json
PCB_[Internet of Things] Hongmeng Internet of Things—Smart WiFi Switch_3_2022-09-24.pcbdoc
Gerber_PCB_[Internet of Things] Hongmeng Internet of Things—Smart WiFi Switch_3.zip
Schematic_[Internet of Things] Hongmeng Internet of Things—Smart WiFi Switch_2022-09-24.pdf
SCH_[Internet of Things] Hongmeng Internet of Things—Smart WiFi Switch_2022-09-24.json
Hongmeng Smart WiFi Switch_2022-09-24.schdoc
61518
[Training Camp] Internet of Things Clock Wu Kaimao
Introduction: Clock based on ESP-C3-12F WIFI chip module
Design an IoT clock project using Essence ESP-C3-12F WIFI chip
IMG_7540(1).MP4
BOM download
PCB_IoT clock PCB_2022-09-24.pdf
PCB_IoT clock PCB_2022-09-24.json
IoT clock PCB_2022-09-24.pcbdoc
Gerber_IoT clock PCB.zip
Schematic_[Training Camp] Internet of Things Clock Wu Kaimao_2022-09-24.pdf
SCH_[Training Camp] Internet of Things Clock Wu Kaimao_2022-09-24.json
[Training Camp] Internet of Things Clock Wu Kaimao_2022-09-24.zip
61519
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 05:52:11
