王达业
8838 front and rear panels
1. T12 soldering station front panel, suitable for 8838 shell. For the following projects: Open T12 Suzaku T12
2. Suitable for this 8838 shell: "88*38 aluminum profile shell aluminum alloy shell diy aluminum box split aluminum shell shell power box T12 shell" The length I customized is 12cm, the price is 15 yuan, and the color is oxidized black. Note that if you do not customize the default length is 6cm!
3. The GX12-5 core through-the-wall aviation socket used: "Aviation plug socket GX12-2/3/4/5/6P core male and female connector connector" model is GX12-5 core complete set
   of AC power sockets used: "All-copper AC power socket with KCD1/3/4/5 rocker switch with 10A fuse three-in-one/integrated" model is all-copper AC-01 (integrated KCD1 switch)
   OLED acrylic panel used: "t12 digital display soldering station oled screen aluminum alloy shell front panel silver white 6mm thickened acrylic panel" model is a single window acrylic small piece
4. Disclaimer: The shell sizes of each manufacturer are different, and others may not match. Please determine whether it is suitable or modify it before use. The links listed here have nothing to do with me and are for reference only.
5. The real photo
612y53zZ44Q9WhmPZFSkex0XPWVLfO2mYpnCRSWF.pngmqNnjE893JbYTbozyXFLhMqiiY8F8Ph0oiVSAtc7.pngshows 8838 front and rear panels_GX12-F-5 perforated + AC. There is a DC version in the open source file. You can choose to make the board according to your needs.
6. Thanks to 8838 front and rear panels_GX12-F-5 through-wall aviation plug. This project is modified based on this project, and the source project file is also included in the open source file.
END
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:03:45
  • Who can guess what this is for...
  • STM Arduion cannot download firmware?
  • The most classic 51 tutorial
  • MSP430F5438A serial port
  • Airlabi supports 2018 STM32 seminar
  • USB interface chip CY7C68013 (3)
