newrudeman
WS281x LED RS485 transceiver
2-layer PCB 10 x 18 mm FR-4, 1 mm, 1, HASL with leads, white solder mask, black silkscreen; configurable with RS485 TX-RX transceiver for long distance serial LED strip communication WS281x 485 This is a versatile and configurable RS485 TX-RX transceiver for long-distance serial LED light strip communication. If you need to send data to a remote LED strip, you can use one PCB as TX and one as RX, it's easy! They can also be powered from 5V to 12V, so support all different types of LED strips. The PCB can be configured as RX or TX by soldering jumpers and using the correct resistors: RX configuration: R2 and JP32101433871483.jpg
WS281x 485_TX-2.00_2.00-SCH
WS281x 485_RX-2.00_2.00-SCH
75280
Open source current probe based on Rogowski coil
This project is a Rogowski coil based current probe designed to measure high frequency AC current in small spaces. The sensing coil is optimized to be small enough to fit between the leads of a TO-220 transistor and can be slid around the leads of many through-hole power components for non-intrusive current measurements. The project consists of a Rogowski coil and an integrator/amplifier that conditions the signal from the Rogowski coil and provides an output voltage proportional to the current flowing in the conductor surrounded by the Rogowski coil. The sensing coil is open ended and the free end is held in place by a fixed O-ring. This allows the coil to be placed around the wire without breaking the circuit. The amplifier provides a 0.1V/A output via an SMA connector and is designed to drive a 1M oscilloscope input via coaxial cable. The amplifier is powered via a USB-B connector and consumes less than 2W. Typical Electrical Performance Bandwidth: 800 Hz - 25 MHz Sensitivity: 0.1 V/A Maximum Current: +/- 30 A Noise: 6mA RMS Slew Rate: 1 A/ns Coil OD: <1.7mm Length: 70mm Current probes meet The original design target is suitable for general laboratory use. Recently manufactured versions of the integrator have some issues with wireless signal (WiFi and LTE) interference. The PCB files in the latest submission have layout changes to accommodate the circuitry under the metal shield can, which should largely resolve the issue. Only minor electrical modifications have been made in the updated version, but they have not yet been tested.
Schematic diagram, design description, etc.
75578
Open source USB2.0 high-speed analyzer
The analyzer host computer directly uses Wireshark. The hardware is implemented using Cypress CY7C68013A MCU + Lattice LCMXO2 FPGA + Microchip USB3343 USB PHY
Schematic, PCB, firmware, etc.
75579
TI ultra-low power wireless vibration sensor monitors motor reference design
Implement preventive maintenance, CR2032 button battery can provide power for 10 years
This reference design is a low-power wireless subsystem solution that uses vibration sensing to monitor motors to determine if preventive maintenance is needed. FFTs of vibration data can be sent to another device using Bluetooth Low Energy or sub-1GHz wireless protocols. The subsystem solution's low power consumption and wireless capabilities enable it to operate on a single coin cell battery, allowing devices to be small, inexpensive and placed in hard-to-reach locations. This makes this reference design an ideal alternative to preventatively avoidable costly maintenance and the need for larger, more expensive displays that require wired connections. Features - Ultra-low power design enables up to 10 years battery life on a single CR2032 coin cell - Provides mechanical vibration (20ksps) and temperature sensing - 2K FFT local computation for vibration spectrum analysis - Programmable wake-up for motor diagnostics Spacing - Designed for SimpleLink sub-1GHz and Bluetooth Low Energy Wireless LaunchPad (LAUNCHXL-CC1350)
Schematic diagram
BOM
Assembly drawing
CAD/CAE symbol
Gerber
Design guide
75580
Interactive Memory Technology Learning Kit Core64
Core64 combines real core memory and LEDs in a unique interactive way. Core Memory is a magnetic memory technology from the 1960s and 1970s. The tip of the stylus has a magnet that interacts with the LED through Core Memory. In practice, users can think of it as a magnetic touch screen
Core64 combines real core memory and LEDs in a unique interactive way. Core Memory is a magnetic memory technology from the 1960s and 1970s. The tip of the stylus has a magnet that interacts with the LED through Core Memory. In practice, users can think of it as a magnetic touch screen.
Schematics, documentation, firmware, etc.
75581
USB-C "switch", hardware open source, firmware provided
The basic functions of USB-C are supported, such as high-speed communication and charging functions. Then this design solves the problem of painless switching between one host and multiple devices, or one device and multiple hosts.
PCB
firmware
75582
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 12:49:58
