通通
PCM51XX Universal Verification Board
Description:
This verification board is based on the C964085 PCM5102 audio stereo DAC decoder verification board from LiChuang Mall. It has been modified
to add support for PCM512X (PCM5121/PCM5122). PCM512X is configured in hard-wired mode on this verification board, using only its DAC function;
support for 3-wire I2S is added (3-wire I2S has no master clock signal MCK/SCK), which is achieved by shorting the SCK pin of the DAC to ground;
a level selection jumper is added to control the AGNS (gain selection) pin of PCM512X. The output gain is 2VRMS at a low level and 1VRMS at a high level;
the analog output end only retains the advanced 3.5mm audio output port, and the mode selection pin is removed from the digital end;
a TVS is added to the 5V power input for ESD protection.
The chips supported by this verification board
        are PCM510X series: PCM5100, PCM5101, PCM5102
                                          PCM5100A, PCM5101A, PCM5102A
                                          PCM5100A-Q1, PCM5101A-Q1, PCM5102A-Q1 (the ones with Q1 are automotive grade)
        For PCM510X series: PCM5121, PCM5122
Physical display:
When connected to the CM6631A digital interface, sound came out immediately, and beautiful music came out from the other end of the earphone...
This digital interface supports up to 32bit/384k (but it is not very stable, probably because of the 6631 firmware). After adjusting to the maximum specification, use this verification board to play sound without any noise.
eH2fhBzB7SoiPhYzU8udM02iZe0PbRQsutiCrQ0Y.pngTest video:
Network disk address: https://pan.baidu.com/s/1JX9opbWTkPyZhCnlKTJMgA Extraction code: 5102
Appendix:
Chip data sheet
PCM5100, PCM5101, PCM5102: https://www.ti.com.cn/cn/lit/gpn/pcm5100
PCM5100A, PCM5101A, PCM5102A (and Q1): https://www.ti.com.cn/cn/lit/gpn/pcm5100a
PCM5121, PCM5122: https://www.ti.com.cn/cn/lit/gpn/pcm5122
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 11:51:05
