兰博
Double E Tesla Coil
        Double E Tesla coil, power supply 48V, current less than 2A. The picture shows the size of 80mm*80mm, which is different from the link shared. It is 100mm*100mm. Only the onboard size is different. Others are similar, and the effect is the same and very good. It can be connected to a mobile phone via Bluetooth and can only play square wave music. The Bluetooth module used is an easy-to-find module in TB, M18.
Secondary coil parameters: 50mm acrylic tube, 0.12mm enameled wire, winding height 65mm.
Data link: https://pan.baidu.com/s/1GSPmjLQ-Jvm3_F2NwVbJzA Extraction code: 8888
PCB screenshot:
Physical PCB:
Acrylic shell:
Secondary coil:
Finished product display:
Discharge effect:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 07:24:36
