红水杯
pico rocker chip
Original address of the pico-based joystick chip
: https://github.com/FeralAI/PicoFightingBoard
Source b: https://www.bilibili.com/video/BV1EF411M7Sf?spm_id_from=333.880.my_history.page.click
Proofing completed , all keys are available after testing. The V1.3 version was added
on 2022-06-22
. The difference from the previous version is that the pin position has been modified. This layout is more suitable for Chinese people's usage habits.
Added a reset button.
Pico.Fighting.Board.v1.1.Quick.Reference.pdf
GP2040-PicoFightingBoard_v0.4.3.uf2
BOM download
PCB_V1.3_2022-09-22.pdf
PCB_V1.3_2022-09-22.json
V1.3_2022-09-22.pcbdoc
Gerber_V1.3.zip
PCB_V1.0_2022-09-22.pdf
PCB_V1.0_2022-09-22.json
V1.0_2022-09-22.pcbdoc
Gerber_V1.0.zip
Schematic_pico rocker chip_2022-09-22.pdf
SCH_pico rocker chip_2022-09-22.json
pico rocker chip_2022-09-22.zip
62029
Solder paste pusher
Introduction: USB powered handheld syringe packaging solder paste pusher
It is powered by USB C and controls two motors to push the solder paste syringe, saving time and effort
. Demonstration video. Demonstration video
https://www.bilibili.com/video/BV1n44y1j7c6?share_source=copy_web
driver chip TC118S (the same pin position is acceptable)
3 types of PCB (circuit drive and bracket)
M3 copper pillar + M3 screw (bracket)
N20 reduction motor (Xiaobao 7 yuan 2 free shipping)
coupling (3mm-6mm)
screw M6 (acting as a lead screw)
nut M6 (acting as a lead screw ) Slide table)
-- excluding PCB, the cost is less than 30 yuan
BOM download
PCB_syringe thruster.PcbDoc_2022-09-22.pdf
PCB_syringe thruster.PcbDoc_2022-09-22.json
Syringe pusher.PcbDoc_2022-09-22.pcbdoc
Gerber_syringe thruster.PcbDoc_2022-09-22.zip
62030
Planck keyboard, 40% layout, three modes
Introduction: Planck three-mode PCB layout file, because it was drawn using other software, the 3D drawing of the light is sealed, and the actual layout will not be affected.
1. The only correction to the inverted shaft light is that the shaft seat may need to be polished before it can be installed.
2. Only steel plate satellite shafts can be used, and the space is limited.
The light control uses is31fl3733
8 bottom lights WS2812_5050
4 ws2812_2020 package status indicators (light 1: caps, numlock, light 2: Bluetooth 1: red, Bluetooth 2: blue, Bluetooth 3: green and 2.4G indicator: white, light 3 : Layer indicator, light 4: USB indicator) With driver, it can be modified at will.
Use U disk to drag and drop to upgrade the firmware.
QQ group: 1121219685
M2_PLANCE_2022_02_04-1941ea2.uf2
zoro_planck.zip
BOM for ZORO_P.xlsx
Pick Place for ZORO_P.csv
BOM download
62031
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 22:40:46
  • Passive Low-Pass Filter and Non-Inverting Amplifier Related Issues
  • I-cache question
  • Sell a few boards, chipkit32, LPC800mini, encoder, tank...
  • ARM state and THUMB state
  • VHDL source code for three-wire SPI interface
  • Identification of long and short keys of MSP430G2553 external interrupt
