红水杯
Type c female port housing fixing bracket
Gerber_type-c_2022-02-23.zip
BOM download
62062
[Internet of Things] Hongmeng Smart Switch
Introduction: None
Lichuang Hongmeng smart switch, remotely control the light switch on your mobile phone
WeChat_20220406113347.mp4
BOM download
Schematic_[Internet of Things] Hongmeng Smart Switch_2022-09-22.pdf
SCH_[Internet of Things] Hongmeng Smart Switch_2022-09-22.json
Smart switch-schematic diagram_2022-09-22.schdoc
PCB_Smart switch-PCB_2022-09-22.pdf
PCB_Smart Switch-PCB_2022-09-22.json
Smart switch-PCB_2022-09-22.pcbdoc
Gerber_Smart switch-PCB.zip
62063
Handheld photography fill light
Introduction: This is a handheld photography fill light, or photography light.
Use lamp beads RA=95; there are three power consumption brightnesses, and are equipped with 3D printed shells to choose from.
Figure Photography Fill Light
This project contains three versions of fill light:
12V medium cup (rated power consumption 12V@1.7A)
12V large cup (rated power consumption 12V@3.2A)
24V extra large cup
photography effect
shooting ambient
light source : A 12V medium cup version of the fill light
Background: Double-layer A4 paper
Equipment: Redmi K30Pro
Camera parameters: Full Auto
project BOM
light board (choose one of three medium cup, large cup and extra large cup)
lamp beads (STW9Q14D)
silicone grease ( Any model, but the thermal conductivity must be greater than 1)
Shell (see attachment)
cooling fan (24V 80mm x 80mm x 10mm)
radiator, the actual cup in
the picture, the extra large cup QA Q: How much does it cost? A: About 80 with case, about 40 without case. Q: Is it possible to use passive cooling without a cooling fan? A: No
Fill light housing-bottom 4.0.STL
Fill light housing-top cover 3.0.STL
BOM download
PCB_24V light panel extra large cup_2022-09-22.pdf
PCB_24V light board extra large cup_2022-09-22.json
24V light panel extra large cup_2022-09-22.pcbdoc
Gerber_24V light panel extra large cup.zip
PCB_12V light panel medium cup_2022-09-22.pdf
PCB_12V light board medium cup_2022-09-22.json
12V light panel medium cup_2022-09-22.pcbdoc
Gerber_12V light panel medium cup_2022-09-22.zip
PCB_12V light board big cup_2022-09-22.pdf
PCB_12V light board big cup_2022-09-22.json
12V light board large cup_2022-09-22.pcbdoc
Gerber_12V light panel large cup.zip
62064
ST-Link V2.1
Introduction: Self-made ST-Link V2.1 not only realizes the ST-Link download function, but also adds the serial port function to realize one-line download program and serial port debugging function.
# According to ST’s official schematic diagram, a ST-Link downloader circuit is simplified, which not only realizes the program download function, but also realizes the function of the serial port
# At the same time, a 3D package is added to each component to facilitate an intuitive understanding of the real thing
. Everyone is welcome to point out shortcomings
BOM download
PCB_ST-Link V2.1_PCB_2022-09-22.pdf
PCB_ST-Link V2.1_PCB_2022-09-22.json
ST-Link V2.1_PCB_2022-09-22.pcbdoc
Gerber_ST-Link V2.1_PCB.zip
Schematic_ST-Link V2.1_2022-09-22.pdf
SCH_ST-Link V2.1_2022-09-22.json
ST-Link V2.1_Schematic_2022-09-22.schdoc
62065
65w portable heating table
Introduction: The PID temperature control heating stage based on STM32F103C8T6 is very convenient and easy to use. It can display parameters through OLED and control the operation with an encoder.
As for why I want to do this project, I mainly made this heating table for the sake of portability, cheapness and low power.
  First, let’s briefly talk about the principle. The basic principle is PWM pulse width modulation. The PWM duty cycle is adjusted through the measured temperature and temperature preset value, and the MOS tube is driven to achieve the temperature control effect.
  Because it is the first version, the appearance is relatively simple, but there is no problem in normal use. I tested it at 200 degrees and continued to work for 20 minutes, and no problems were found. However, it is still recommended not to use it at high temperatures for too long. It is recommended to use it below 230 degrees. Generally, 200 degrees is enough for desoldering work.
  The outer casing is printed with ABS. You can find the same STM32 board on Taobao. I will design a board myself in the future. The tape uses high silicone tape, which is easy to use and has sufficient temperature resistance. As for high temperature resistant glue, I used Boyan 3+3 red glue, which is very easy to use.
  For power supply, PD65W is used. It can be used just by plugging it in, which is very convenient. This version does not have fast charging integrated on the board. I will update it after the subsequent verification is completed.
  The module needs a 20v to 5v DC-DC module for power supply. A few dollars on Taobao is a lot.
https://www.bilibili.com/video/BV1YS4y1k74Z
Remember to give me a like and a coin~
65w heating table.zip
BOM download
PCB_65w heating table-second_2022-09-22.pdf
PCB_65w heating table-second_2022-09-22.json
65w heating table-second_2022-09-22.pcbdoc
Gerber_65w heating table-second_2022-09-22.zip
PCB_second_7.2R_2022-10-02.pdf
PCB_second_7.2R_2022-10-02.json
second_7.2R_2022-10-02.pcbdoc
Gerber_second_7.2R_2022-10-02.zip
62066
Spectrum light based on ESP32
Introduction: Various special effect spectrum lights based on ESP32/arduino nano.
Open source project-spectrum light.7z
BOM download
62067
Portable mini heating table V2.0
Introduction: The PID temperature control heating stage based on STM32F103C8T6/C6t6 is very convenient and easy to use. The new version has a self-made menu UI, which can adjust various parameters through the encoder. It is more practical than the first version and also enhances stability. ,Multi-PD protocol support.
 The second version will be more practical, beautiful and stable. Similarly, all modules in the second version will be open source and can be customized, including STM32 master control and PD protocol modules. The second edition will also have more comprehensive information.
The development environment
uses KEIL5 and is developed based on the STM32F103C8T6 or C6T6 standard library (in actual testing, this version of the program is compatible with C8T6 and C6T6A).
Progress update:
March 15, 2022.
  The program framework has been written, and the menu and UI framework have been built. The first version of PCB is being drawn. On
March 20, 2022,
  the fast charging protocol module based on CH224K has been experimentally completed. Can output 20v, 15v, 12v, 9v voltage.
On March 31, 2022,
  the PCB and program were basically completed. Start sample testing. The PCB has been received
on April 5, 2022
  , and testing of stability and actual usage has begun.
  The basic test passed, there are no major problems in the program, some minor bugs have been solved, the PID has been roughly adjusted, and the OLED refresh rate has been optimized to make the animation smoother.
  Optimized the reading of the encoder, making the reading more accurate and stable. In terms of hardware, due to the difficulty and cost of production, the next board drawing separates the MCU main control and the board and uses pin headers to connect them. This can reduce the difficulty and cost of production.
  After half an hour of constant temperature testing at 200°C, the MOS was about It is 40+ degrees, and LDO generates a lot of heat, about 60 degrees. Heat dissipation needs to be enhanced in the future. The MOS tubes should be managed together to reduce heat generation. The LDO is equipped with a heat sink.
On April 6, 2022,
 the new PCB has been drawn, and this version is expected to be a stable version. It solves the production difficulty, cost and heat dissipation issues. The 3D shell drawing is completed.   The v2.0 PCB has been verified on
April 10, 2022  , and the 3D shell is on the way. Officially released on April 17, 2022  ! ! ! ! Summary MCU: STM32f103c8t6 (or c6t6A)  Power supply: PD protocol includes 20v, 15v, 12v, 9v (20v is recommended) Chip: CH224K Control: Encoder SIQ-02FVS3 Display: 0.96-inch OLED (IIC) Heating plate: Aluminum substrate (approx. 6.8Ω) Temperature detection: K-type thermocouple + MAX6675 Function introduction The heating stage controls the temperature through PWM pulse width modulation. Main interface: (1) Display parameters: The upper left corner displays the current temperature, the thermometer icon on the left represents the current temperature level, the battery icon represents the current power supply voltage, and the right side is like a pull cord for mode switching display. The lower slider and the temperature on the right are to set the target temperature. (2) Control: You can set the target temperature by scrolling the encoder left and right, and press the encoder to switch to the preset temperature mode with one button. Menu interface: (1) Voltage: Control the power supply voltage. (2) Temperature: Set the temperature step. (3) Setting: Set the temperature of the three modes. (4) Personalization: Not used yet. If you have any desired functions, you can put them here. (5) Return: Return to the main interface. Demonstration video (if you think it is good, please like and vote, you know~) Portable Heating Table V2.0 Open Source Mini Digital Display Heating Table_bilibili_bilibili The overall appearance of the 3D shell can be made of nylon or ABS, I am The nylon material used is made by Jiali Chuang. The texture is really good. The project has been successfully exported. For details of the PCB project file, please see attachment 2. Then the PCB plate making file and BOM have precautions  in attachment 1 (1) The mos tube generates less heat. , you don’t need to install a heat sink (add it if you can), LDO generates a lot of heat, so you need to install a heat sink, and plate the window part with solder to enhance heat dissipation. (2) The aluminum substrate is conductive, so during production, be careful not to contact the two wires connecting the aluminum substrate with the aluminum part of the aluminum substrate. (3) Pay attention to the positive and negative polarities of the K-type thermocouple. (4) Be careful not to use the heating table at high temperature for a long time. Generally, 200 degrees is enough to melt tin. In actual tests, there is no problem in continuous use at 200 degrees for 20 minutes. (5) Pay attention to distinguish the 8M crystal oscillator type of the STM32 core board. If it is a passive crystal oscillator, the new STM chip may cause the passive crystal oscillator to not vibrate and not work properly (of course there is no need to buy a brand new one, the new one is too expensive. Buy a refurbished genuine c6t6A for only 7 yuan each) (6) The screws and studs used in assembly are all M2 models.
Portable heating table.zip
PCB project file.zip
62068
Buck-single-turn dual power strip
Introduction: During the preparation for the electronic competition, I accumulated some proven power boards. This time I open sourced two single-turn dual power boards, one of which can output 3V3 with high current and low ripple.
Module 1: TPS5450 is a 5.5V to 36V input 5A 500kHz buck converter. This power board supports a maximum input of 36V (pay attention to the capacitor voltage resistance selection), and is a single-power to dual-power adjustable output power module.
Module 2: MPM3620 is used as the 8-18V input of the step-down part. After step-down, it outputs plus and minus 5V, plus and minus 1A through two LDOs. The power module has strong load capacity, extremely low ripple, extremely low noise, and is fast. Transient response.
Module 3: Using MPM3830 as the step-down input, the input voltage is fixed at +5V, the output voltage is 3.6V, and 3.3V is output through the LDO. Mainly used for chips that require large current and low ripple, such as AD9854 (DDS). The LDO model is MAX8556, which is an ultra-low input voltage regulator that can output a current of 4A at a voltage drop of 100mV.
   For electric competition use, generally speaking, it does not require too much current. It is mainly used to convert single power supply to dual power supply to supply power to dual power supply op amps, etc.
(In preparation for the provincial competition, I will open source some modules during the break. I will sort out the information after the provincial competition and open source some ADC, DAC, and DDS. It should be a series.)
62069
Open source wearable watch (including firmware, schematics and 3D printing diagrams)
This smartwatch can measure linear acceleration, rotational speed, heart rate and SpO2 (oxygen saturation) of the hand
Open-Watch is an open source smartwatch project developed by B.Sc. This smartwatch can measure linear acceleration, rotational speed, heart rate, and SpO2 (oxygen saturation) of the hand. All this data will be processed by the STM32 processor with ARM Cortex-M core.
MPU6050 is used for IMU purpose, using Kalman filter to reduce noise effects and extract clean data from sensors (3-axis linear acceleration, 3-axis rotation speed and 3-axis rotation angle).
The MAX30102 is a sensor for healthcare purposes that simply reads raw data and moves the process to a smartphone.
Open-watch will send this collected data to a smartphone via a Bluetooth module. On the smartphone side, the Android app reads the data from Bluetooth and processes it. For healthcare applications such as heart rate and SpO2 analysis, ML-based algorithms are used to extract these parameters from the raw data read by the pulse oximeter sensor.
open-watch-master
62070
Teacher ChaN’s headphone amplifier design
FatFS author ChaN teacher open source design
Teacher ChaN’s headphone amplifier design for reference
hpa_ctrl
Create documentation
62071
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 03:10:05
