newlandmark
FEBFL77904-L82H08A-GEVB: 8 W AC LED Driver
The FEBFL77904-L82H08A-GEVB is a direct AC line LED driver with a minimum number of external RC passive components. In normal configuration, one resistor is used to regulate the LED power and one capacitor is used to provide a stable voltage for the internal bias shunt regulator. The FEBFL77904-L82H08A-GEVB provides phase-cut dimming with a wide dimming range, smooth dimming control, and good dimmer compatibility. It achieves high efficiency, high PF, and low THD, which makes the FL77904 suitable for high-efficiency LED lighting systems. The high-power design of the FEBFL77904-L82H08A-GEVB can be achieved by embedding multiple ICs in parallel, which is suitable for streetlight and downlight applications. Features & ApplicationsFeaturesSimplest direct AC line LED driver with only two external RC passive componentsWide AC input range: 90~305 VAC Four integrated high-voltage LED constant current sources, up to 75 mA (RMS) TRIAC dimming (leading/trailing edge) Variable resistor dimmingHigh power factor (above 0.98 in normal configuration) Adjustable LED power supply with external current sense resistorLow harmonic content (THD below 20% in normal configuration) SOP 8LD packageFlexible LED forward voltage configurationPower scalability with multiple driver ICsOver temperature protection (OTP)
The FEBFL77904-L82H08A-GEVB is a direct AC line LED driver with a minimal number of external RC passive components. In normal configuration, one resistor is to adjust LED power, and one capacitor is to provide a stable voltage to an internal biasing shunt regulator.
The FEBFL77904-L82H08A-GEVB provides phase-cut dimming with wide dimming range, smooth dimming control and good dimmer compatibility. It achieves the high efficiency with high PF and low THD which makes the FL77904 suitable for high-efficiency LED lighting systems.
High wattage design of the FEBFL77904-L82H08A-GEVB can be implemented with multiple IC embedded in parallel for street lighting and down lighting applications.
Features and Applications
The simplest Direct AC LED Driver with Only Two External RC Passive Component
Wide AC Input Range: 90~ 305 VAC
Four Integrated High-Voltage LED Constant Current Sinks of up to 75 mA (RMS) Capability
TRIAC Dimmable (Leading/Trailing Edge)
Rheostat Dimmable
High Power Factor (above 0.98 in normal configuration)
Adjustable LED Power with an External Current Sense Resistor
Low Harmonic Content (THD under 20% in normal configuration)
SOP 8LD Package
Flexible LED Forward Voltage Configuration
Power Scalability with Multiple Driver ICs
Over-Temperature Protection (OTP)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 14:39:25
