fish001
STR-NCD98010-GEVK:Strata Enabled NCD98010 12-bit SAR ADC Evaluation Board
STR-NCD98010-GEVK: Strata Enabled NCD98010 12-bit SAR ADC Evaluation Board
The STR-NCD98010-GEVB provides an evaluation board for the NCD98010 driver using the Strata Developer Studio. The NCD98010 is an ultra low power 12-bit SAR ADC that can run up to 2MSPS. The NCD98010 is available in a small 1.5mm x 1.5mm DFN package. This evaluation board is used with Strata to control the NCD98010 and provide dynamic performance metrics for different clock speeds and supply voltages. For more details, see the Strata web page www.onsemi.com/strata! Click to Download Strata Features and Applications Features 12-bit analog to digital conversion - Fully differential inputs - Low 2pF input capacitance Digital SPI interface - Signed and unsigned output formats available Split analog/digital power - Digital and analog supplies can be powered separately from 1.65V to 3.6V Low power - 7uA at 100 kSPS - Analog current consumption can be reduced to nanoamps with lower clock rates Small package size - 1.5 x 1.5 mm 8-pin X2QFN Pre-calibrated Applications Low power data acquisition - Battery powered devices - Level sensors - Ultrasonic flow meters - Motor control - Wearable fitness devices - Portable medical devices - Glucose meters
The STR-NCD98010-GEVB provides an evaluation board for the NCD98010 driver using Strata Developer Studio. The NCD98010 is a ultra low power 12-bit SAR ADC that can run at up to 2MSPS. The NCD98010 comes in a small 1.5mm x 1.5mm DFN package. This evaluation board is used with Strata to control the NCD98010 and to provide dynamic performance metrics for different clock speeds and supply voltages. See the Strata webpage at www.onsemi.com/strata for more details! Click to Download Strata
12-bit Analog to Digital Conversion
- Fully Differential Input
- Low 2pF Input Capacitance
Digital SPI Interface
- Available in Sign ed and Unsigned Output Formats
Split Analog / Digital Supplies
- Digital and Analog Supplies can be Supplied Separately from 1.65V to 3.6V
Low Power Consumption
- 7uA at 100 kSPS
- Analog Current Consumption CAN to go down to nano-amps with Slower Clock Rates
Small Package Size
Pre-Calibrated
Low-Power Data Acquisition ition
- Battery-Powered Equipment
- Level Sensors
- Ultrasonic Flow Meters
- Motor Controls
- Wearable Fitness Devices
- Portable Medical Equipment
- Glucose Meters
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 18:44:35
