宋元浩
FEBFL77904-L82L08A-GEVB: 8 W AC LED Driver
The FEBFL77904-L82L08A-GEVB is a direct AC line LED driver with a minimum number of external RC passive components. In normal configuration, one resistor is used to regulate the LED power and one capacitor is used to provide a stable voltage for the internal bias shunt regulator. The FEBFL77904-L82L08A-GEVB provides phase-cut dimming with a wide dimming range, smooth dimming control, and good dimmer compatibility. It achieves high efficiency, high PF, and low THD, which makes the FEBFL77904-L82L08A-GEVB suitable for high-efficiency LED lighting systems. The high-power design of the FEBFL77904-L82L08A-GEVB can be achieved by embedding multiple ICs in parallel, which is suitable for streetlight and downlight applications. Features & ApplicationsFeaturesPower scalability through multiple driver ICsFlexible LED forward voltage configurationSOP 8LD packageHigh power factor (above 0.98 in normal configuration)Variable resistor dimmableTRIAC dimming (leading edge/trailing edge) Four integrated high-voltage LED constant current sources, up to 75 mA (RMS) Wide AC input range: 90~305 VACThe simplest direct AC LED driver, only two external RC passive componentsAdjustable LED power supply with external current sense resistorLow harmonic content (THD below 20% in normal configuration)Over temperature protection (OTP)
The FEBFL77904-L82L08A-GEVB is a direct AC line LED driver with a minimal number of external RC passive components. In normal configuration, one resistor is to adjust LED power, and one capacitor is to provide a stable voltage to an internal biasing shunt regulator.
The FEBFL77904-L82L08A-GEVB provides phase-cut dimming with wide dimming range, smooth dimming control and good dimmer compatibility. It achieves the high efficiency with high PF and low THD which makes the FEBFL77904-L82L08A-GEVB suitable for high-efficiency LED lighting systems.
High wattage design of the FEBFL77904-L82L08A-GEVB can be implemented with multiple IC embedded in parallel for street lighting and lighting down applications.
Features and Applications
Power Scalability with Multiple Driver IC s
Flexible LED Forward Voltage Configuration
SOP 8LD Package
High Power Factor (above 0.98 in normal configuration)
Rheostat Dimmable
TRIAC Dimmable (Leading/Trailing Edge)
Four Integrated High-Voltage LED Constant Current Sinks of up to 75 mA (RMS) Capability
Wide AC Input Range: 90~305 VAC
The simplest Direct AC LED Driver with Only Two External RC Passive Component
Adjustable LED Power Sense Res istor
Low Harmonic Content (THD under 20% in normal configuration)
Over-Temperature Protection (OTP)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 19:27:12
  • About system software transplantation?
  • Newbie seeking advice
  • Circuit question?
  • About the board driver problem of 430f5529
  • Wangbao IoT Board Simulation Gateway Routine
  • IOS BLE4.0 low-power Bluetooth connection and data transmission and reception process
