toothache
NV890200PDR2GEVB: Automotive Switching Regulator, 2 A, 2 MHz, Evaluation Board
NV890200PDR2GEVB: Automotive Switching Regulator, 2 A, 2 MHz, EVALUATION BOARD
The NCV890200 is a fixed-frequency, monolithic, Buck switching regulator intended for Automotive, battery-connected applications that must operate with up to a 36V input supply. The regulator is suitable for systems with low noise and small form factor requirements often encountered in automotive driver information systems. The NCV890200 is capable of converting the typical 4.5 V to 18 V automotive input voltage range to outputs as low as 3.3 V at a constant switching frequency above the sensitive AM band, eliminating the need for costly filters and EMI countermeasures. The NCV890200 also provides several protection features expected in Automotive power supply systems such as current limit, short-circuit protection and thermal shutdown. In addition, the high switching frequency produces low output voltage ripple even when using small inductor values and an all-ceramic output filter capacitor - forming a space-efficient switching regulator solution.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 03:54:07
  • Relay drive problem. . Solution
  • WinCE Bluetooth problem solved thanks
  • How to put constant array in code segment in ARM?
  • HPS-to-FPGA access to FPGA I/O
  • The FPGA pin corresponding to the common IO signal on the PCB is the global clock
  • I hope the experts can give me some advice.
