走马观花
FEBFL77905-L83H08A-GEVB: 8W AC LED Driver
The FEBFL77905-L83H08A-GEVB is a direct AC line LED driver with a minimum number of external RC passive components. In normal configuration, one resistor is used to regulate the LED power and one capacitor is used to provide a stable voltage for the internal bias shunt regulator. The FEBFL77905-L83H08A-GEVB provides phase-cut dimming with a wide dimming range, smooth dimming control, and good dimmer compatibility. It achieves high efficiency, high PF, and low THD, which makes the FL77905 suitable for high-efficiency LED lighting systems. The FL77905 has a dedicated DIM pin that can be used for analog or digital PWM dimming. The high power design of the FEBFL77905-L83H08A-GEVB can be achieved by embedding multiple ICs in parallel, which is suitable for streetlight and downlight applications. Features & ApplicationsFeaturesPower scalability through multiple driver ICsFlexible LED forward voltage configurationSOP 8LD packageLow harmonic content (THD below 20% in normal configuration)High power factor (above 0.98 in normal configuration)Dimmable varistorsFour integrated high-voltage LED constant current sources, up to 75 mA (RMS)Wide AC input range: 90~305 VACSimplest direct AC LED driver, only two external RC passive componentsAnalog/digital PWM dimming functionTRIAC dimming (leading/trailing edge)Adjustable LED supply over-temperature protection (OTP) with external current sense resistorThe
FEBFL77905-L83H08A-GEVB is a direct AC line LED driver with a minimal number of external RC passive components. In normal configuration, one resistor is to adjust LED power, and one capacitor is to provide a stable voltage to an internal biasing shunt regulator.
The FEBFL77905-L83H08A-GEVB provides phase-cut dimming with wide dimming range, smooth dimming control and good dimmer compatibility. It achieves the high efficiency with high PF and low THD which makes the FL77905 suitable for high-efficiency LED lighting systems. The FL77905 has a dedicated DIM pin which can be used with analog or digital PWM dimming.
High wattage design of the FEBFL77905-L83H08A-GEVB can be implemented with multiple IC embedded in parallel for street lighting and down lighting applications.
Features and Applications
Power Scalability with Multiple Driver ICs
Flexible LED Forward Voltage Configuration
SOP 8LD Package
Low Harmonic Content (THD under 20% in normal configuration)
High Power Factor (above 0.98 in normal configuration)
Rheostat Dimmable
Four Integrated High-Voltage LED Constant Current Sinks of up to 75 mA (RMS) Capability
Wide AC Input Range: 90~305 VAC
The simplest Direct AC LED Driver with Only Two External RC Passive Component
Analog/Digital PWM Dimming Function
TRIAC Dimmable (Leading/Trailing Edge)
Adjustable LED Power with an External Current Sense Resistor
Over-Temperature Protection (OTP)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 20:33:24
