ghaytweyhtoo
AM306238R1DBGEVB: Daughter Board LIN Stepper Driver with Stall Detection (SOIC) Evaluation Board
AM306238R1DBGEVB:  Daughterboard LIN Stepper Driver with Stall Detection (SOIC) Evaulation Board
The AM306238R1DBGEVB is a footprint reference design that provides a complete solution for driving bipolar stepper motors. Combined with the AMIS3062xAGEVK evaluation kit, it forms a LIN-based solution that converts high-level commands from a LIN master into well-defined motions. The design can be programmed to detect mechanical blocking of the rotor and take action. It also features a minimal bill of materials, small board size, and perfectly matched thermal resistance, allowing 800 mA to be driven at elevated ambient temperatures. Note: This board must be used with the AMIS3062XAGEVK automotive stepper motor driver kit. Features & ApplicationsFeaturesLow Bill of MaterialsSmall size (25mm x 24mm) Plug and Play in conjunction with the AMIS3062xAGEVK LIN interfaceMicrostepping (1/2, 1/4, 1/8, 1/16) Sensorless stall detectionPeak current 800mA 8V-29V supply voltage automotive compliantFull diagnostics and status informationPosition controllerConfigurable speed, acceleration and decelerationProgrammable hold and run currentsApplicationsFlap control in HVAC systemsHeadlight positioning systemsThe
AM306238R1DBGEVBis a form factor Reference Design providing a complete solution driving bipolar stepper motors. In conjunction with the AMIS3062xAGEVK evaluation kit it forms a LIN based solution turning high level commands from a LIN master in well defined motions. The design can be programmed to detect and act on mechanical blocking of the rotor. It also incorporates the lowest bill of materials, small board size and perfect matched thermal resistance allowing to drive 800 mA at elevated ambient temperature.Note: This board must be used with the AMIS3062XAGEVK Automotive Stepper Motor Driver Kit.
Features and Applications
Low bill of materials
Small form factor (25mm x 24mm)
Plug and Play in combination with AMIS3062xAGEVK
LIN interface
Peak current of 800mA
Full compliant diagnostic s and status information
Position controller
Configurable speeds, acceleration and deceleration
Headlamp Positioning systems
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 13:43:23
