石榴姐
FEBFSL4110LR-CS01U06A-GEVB: 6.0 W auxiliary power supply
FEBFSL4110LR-CS01U06A-GEVB: 6.0 W Auxiliary Power Supply
The FEBFSL4110LR-CS01U06A-GEVB evaluation board is an integrated pulse width modulation (PWM) controller and 1000 V avalanche rugged SenseFET designed specifically for high input voltage offline switch mode power supplies (SMPS) with minimal external components. VCC can be supplied by the integrated high voltage power regulator, eliminating the need for an auxiliary bias winding. The integrated PWM controller includes a fixed frequency oscillator, undervoltage lockout (UVLO), leading edge blanking (LEB), optimized gate drivers, soft start, temperature compensated precision current sources for loop compensation, and variable protection circuits. Compared to discrete MOSFET and PWM controller solutions, the FSL4110LR reduces total cost, component count, PCB size, and weight; while increasing efficiency, productivity, and system reliability. The device provides a basic platform for cost-effective design of flyback converters. Features and Applications Features Built-in avalanche protected 1000 V SenseFET Accurate fixed operating frequency: 50 kHz VCC can be supplied by the bias winding or self-biased. Various protection functions: Overload protection (OLP), Overvoltage protection (OVP), Abnormal overcurrent protection (AOCP), Internal thermal shutdown (TSD) with hysteresis. Undervoltage lockout (UVLO) with hysteresis and Line overvoltage protection (LOVP). Pulse-by-pulse current limit, fixed 1.6 second restart time, safe auto-restart mode for all protections .
The integrated PWM controller includes a fixed-frequency oscillator,
Under-Voltage Lockout (UVLO), Leading-Edge Blanking (LEB), optimized gate driver, soft-start, temperature-compensated precise current sources for loop-compensation, and variable protection circuitry.
Compared with a discrete MOSFET and PWM controller solution, the FSL4110LR reduces total cost, component count, PCB size, and weight; while simultaneously increasing efficiency, productivity, and system reliability. This device provides a basic platform for cost-effective design of a flyback converter.
Built-in Avalanche Rugged 1000 V SenseFET
Precise Fixed Operating Frequency: 50 kHz
VCC can be supplied from either bias-winding or self-biasing.
Various Protection Functions: Overload Protection (OLP), Over-Voltage Protection (OVP), Abnormal Over-Current Protection (AOCP), Internal Thermal Shutdown (TSD) with Hysteresis. Under-Voltage Lockout (UVLO) and Line Line Over-Voltage Protection (LOVP) with Hysteresis.
Pulse-by-Pulse Current Limit
Fixed 1.6 s Restart Time for Safe Auto-Restart Mode of All Protections
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 01:40:49
