念慈菴
LM2596ATPBCKGEVB: Buck Switching Regulator Evaluation Board
LM2596ATPBCKGEVB:  Step-Down Switching Regulator Evaluation Board
The LM2596 regulator is circuit ideally suited for easy and convenient design of a step-down switching regulator (buck converter). It is capable of driving a 3.0 A load with excellent line and load regulation. This device is available in adjustable output version and it is internally compensated to minimize the number of external components to simplify the power supply design. Demoboard size: 59mm x 44mm
Features and Applications
Adjustable Output Voltage Range 1.23 V 37 V
Guaranteed 3.0 A Output Load Current
Wide Input Voltage Range up to 40 V
150 kHz Fixed Frequency Internal Oscillator
TTL Shutdown Capability
Low Power Standby Mode, typ 80 _A
Thermal Shutdown and Current Limit Protection
Internal Loop Compensation
Moisture Sensitivity Level (MSL) Equals 1
Simple HighEfficiency StepDown (Buck) Regulator
Efficient PreRegulator for Linear Regulators
OnCard Switching Regulators
Positive to Negative Converter (BuckBoost)
Negative StepUp Converters
Power Supply for Battery Chargers
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 10:15:28
