aytwartoofyoroo
NCV705XXLITEGEVK: Evaluation kit for the NCV705XX series
NCV705XXLITEGEVK: Evaluation Kit for NCV705XX Family
The plug-and-play NCV705XXLITEGEVK evaluation kit is packaged in a carton for quick evaluation of the NCV705XX micro-stepping motor driver family. It contains all the hardware and software required to control the NCV705XX device from a PC. A user-friendly graphical user interface (GUI) makes it easy to operate the evaluation kit. The supplied mainboard provides great flexibility in your development process. Easy access to multiple signals makes debugging very easy and allows you to connect the evaluation kit with your own application, reducing development time. The separate daughter boards make it very easy to evaluate the entire NCV705XX family. Note: This kit can be used with the following orderable daughter boards: NCV70517R1DAGEVBNCV70516R1DAGEVBNCV70514R1DAGEVB
The plug-and-play NCV705XXLITEGEVK evaluation kit is delivered in paper box and is intended for fast evaluation of NCV705XX microstepping motor driver family.
It contains all necessary hardware and software needed to control the NCV705XX device from your PC. The user-friendly Graphic al User Interface (GUI) makes it possible to operate the evaluation kit in an easy way.
The provided motherboard gives a lot of flexibility during your development process. Easy access to several signals makes debugging very easy and gives you the possibility to connect the evaluation kit with your own application which reduces the development time.
Evaluation of the complete NCV705XX family is made very easy by means of the separate daughterboards.
Note: This kit can be used with the following orderable daughterboards:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 04:58:01
  • 【Play ESP8266 Together】My Feelings after Understanding McroPython
  • Serial communication problem, CE 5.0 + Evc 4.0 + Sp4 + API
  • Urgent help!!
  • Open1081: First week of getting started with mxchip wifi
  • Share the babies in the forum
  • 【 Don't miss it! 9/10@Shenzhen】2019 WPI/TI Latest PoE Solutions Seminar
