newrudeman
NB4N840MMNEVB: Dual 2x2 Crosspoint Switch Evaluation Board
The NB4N840M Evaluation Board is designed to provide a flexible and convenient platform for quickly evaluating, characterizing, and verifying the performance and operation of the NB4N840M Dual 2 x 2 Crosspoint Switch. The User Manual provides detailed information on the contents, layout, and use of the board. The manual should be used in conjunction with the NB4N840M datasheet, which contains complete technical details on the device specifications and operation. The NB4N840M is a high bandwidth fully differential dual 2 x 2 crosspoint switch with CML inputs/outputs for applications such as SDH/SONET DWDM and high-speed switching. Fully differential design techniques are used to minimize jitter accumulation, crosstalk, and signal skew, making the device ideal for loop and protection channel switching applications. Each 2 x 2 crosspoint switch can fan out and/or multiplex up to 3.2 Gb/s of data and 2.7 GHz clock signals. Features and Applications FeaturesFully assembled evaluation board accommodates electrical characteristics of the NB4N840M in a QFN32 packageEqual length input and output data lines to minimize skewOptional jumpersSingle + 3.3 V power supplyThe
NB4N840M Evaluation Board was designed to provide a flexible and convenient platform to quickly evaluate, characterize and verify the performance and operation of the NB4N840M dual 2 x 2 Crosspoint Switch. The user's manual provides detailed information on the board's contents, layout and use. The manual should be used in conjunction with the NB4N840M data sheet which contains full technical details on device specifications and operation.The NB4N840M is a high-bandwidth fully differential dual 2 x 2 crosspoint switch with CML inputs/outputs that is suitable for applications such as SDH/SONET DWDM and high speed switching. Fully differential design techniques are used to minimize jitter accumulation, crosstalk, and signal skew, which make this device ideal for loop-through and protection channel switching applications. Each 2 x 2 crosspoint switch can fan-out and/or multiplex up to 3.2 Gb/s data and 2.7 GHz clock signals.
Accommodates the electrical characterization of the NB4N840M in the QFN32 package
Selectable jumpers
Single + 3.3 V supply
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 10:13:39
