太白金星
NCP133AMX100TCGEVB:NCP133 XDFN-4 Evaluation Board 1V0
NCP133AMX100TCGEVB: NCP133 XDFN-4 eval board 1V0
The demo board supports the Bias Rail LDO regulator NCP133 in XDFN6 1.2 x 1.2 mm package with Output Voltage 1.0 V and Bias Voltage in range from 2.4 V up to 5.5 V. It is a 500 mA very low dropout device equipped with NMOS pass transistor and a separate bias supply voltage rail. The device provides very stable, accurate output voltage with low noise suitable for space constrained, noise sensitive applications. In order to optimize performance for battery operated portable applications, the NCP133 features low IQ consumption. The device is available with or without active discharge feature.
Size: 50mm x 50mm x 12mm
Features and Applications
Input Voltage Range: 1.3 V to 5.5 V
Bias Voltage Range: 2.4 V to 5.5 V
1.5% Accuracy over Temperature, 0.5% VOUT @ 25°C
Ultra-Low Dropout: Typ. 140 mV at 500 mA
Very Low Bias Input Current of Typ. 80 uA
Logic Level Enable Input for ON/OFF Control
Output Active Discharge Option Available
Stable with a 2,2 uF Ceramic Capacitor
Available in XDFN6 1,2 mm x 1,2 mm x 0,4 mm Package
This is a Pb-Free Device
Battery-powered Equipment
Smartphones, Tablets
Cameras, DVRs, STB and Camcorders, Consumer Electronics
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 16:34:41
