张小哥
STR-USBC-2PORT-100W-EVK: USB Automotive 2-port 100W Power Supply with Strata
STR-USBC-2PORT-100W-EVK: Strata Enabled USB Automotive 2-Port 100W Source
The Strata based Dual 100W USB-PD Automotive Charging System demonstrates ON Semiconductor's broad portfolio of USB-PD and Power Solutions, including the FUSB302 Type-C & PD Port Controller, the FUSB252 HV Protection Switch, and the NCV81599 4-switch buck-boost controller. Additionally, the Strata software also provides full control over the system and allows the user to experiment with various fault and foldback features, change power profiles on each port, and monitor telemetry while charging various load devices. Design collateral such as schematics, PCB layout, test reports, etc. are supplied in the same Strata interface to ease evaluation. See the Strata webpage at www.onsemi.com/strata for more details!Click to Download Strata
Features and Applications
Input: 5V to 32V
Outputs up to 100W Per Port (200W max.)
Default Power Profiles:5/7/9/12/15/20V at up to 5A
Full system; Power, Port + Policy, and Protection
Adjustable Power Profiles: 5V to 20V in 100mV Steps
Fault and Foldback for Temperature & Input Voltage
Cable Compensation
Automotive Qualified Components
Thermal and Battery Protection
Dual USB Type-C Outputs
Benefits
FUSB302T Type-C & PD Port Controller
Low Power Icc=25uA (typical)
─ USB-PD 2.0 Spec Compliant
─ I2C configurable
NCV81599 4-switch Buck-Boost
─ Integrated Drivers
─ I2C Interface to implement USB-PD
─ 20V Protection on CC
─ 16V Protection on D+/D-
─ Surge Protection
Automotive Infotainment and Charging Systems
Industrial and Commercial Transportation
Marine Applications
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 19:51:12
