aerobotics
NCP3064DFBSTGEVB: DFN-8 Boost Evaluation Board
The NCP3064 device supports buck configuration with a wide input voltage range. The NCP3064 is a low-cost converter that supports 1.5A peak current with a maximum duty cycle of 85.7%. An on/off function allows the device to be put into low power mode. 7%. The ON/OFF function allows turn the device to low consumption mode. Features and Applications Features Input Voltage Range from 3.0 V to 40 V Logic Level Shutdown Capability Low Power Standby Mode, Typical 100 uA Output Switch Current to 1.5 A Adjustable Output Voltage Range 150 kHz Frequency Operation Precision 2% Reference Internal Thermal Shutdown Protection Cycle-by-Cycle Current Limit NCV prefix is ​​used in automotive and other applications requiring change of station and control These are lead-free devices Applications Buck, Boost and Inverting Power Supplies Applications High Power LED Lighting Battery Chargers
The NCP3064 device supports a buck configuration with a wide input voltage range. The NCP3064 is a low cost converter that supports a peek current of 1.5A with a maximum duty cycle of 85.7%. The ON/OFF function allows turn the device to low consumption mode.
2% Reference
Cycle-by-Cycle Current Limiting
NCV Prefix for Automotive and Other Applications Requiring Site and Control Changes
These are Pb-Free Devices
Step-Down, Step-Up, and Inverting supply applications
Battery Chargers
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-30 09:29:02
