JFET
NCP718SNT1GEVB: 300 mA Low Iq, Wide Input Voltage Low Dropout Regulator
The NCP718SNT1GEVB is 300 mA LDO Linear Voltage Regulator. It is a very stable and accurate device with ultra-low quiescent current consumption (typ. 4 µA over the full temperature range) and a wide input voltage range (up to 24 V). The regulator incorporates several protection features such as Thermal Shutdown and Current Limiting.
Features and Applications
Adjustable and Fixed Version Available
Operating Input Voltage Range 2.5 V to 24 V
Ultra?Low Quiescent Current typ. 4 µA over Temperature
High PSRR 60dB at 1kHz
Noise typ. 36 µVRMS from 100 Hz to 100 kHz
Stable with 1 µF output capacitor
Soft−start to Reduce Inrush Current and Overshoots
SOA Limiting for High Vin / High Iout – Static and Dynamic
Benefits
Possibility to create any output voltage in range 1.2V to 5V
Wide operating range, suitable for industrial
Improved efficiency during light load conditions
Excellent for power sensitive device
Very well suited for noise sensitive application
Good stability with common and cheap capacitors
Smooth and controlled output voltage raise
Reliable operation under various condition
Wireless charges
Portable equipment
Wireless routers
Battery powered equipment
Industrial power supplies
Communication system
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-12 19:44:32
