smallembedded
NCP781BMNADJTAGEVB: Adjustable Ultra-High Voltage Linear Regulator with Enable Function
NCP781BMNADJTAGEVB: Adjustable Very High Voltage Tolerant Linear regulator with Enable function
The demoboard supports the very high−voltage tolerant linear regulator NCP781 in DFN6 3.3 x 3.3 package with adjustable output voltage in wide range from 1.23 V up to 15 V. The ENABLE function allows turn the device to low consumption mode with quiescent current about 1 uA. The internal configuration allows to create a precise output voltage line with high PSRR. The device is stable with 0.1 uF output capacitor.
Size: 50mm x 50mm x 19mm
Features and Applications
Wide Input Voltage Range: 6 V to 150 V
Output Voltage Versions:
Adjustable: from 1.23 V up to 15 V
±2.5% Accuracy at Room Temperature
Very Low Quiescent Current of Typ. 25 uA
Standby Current: 1 uA
Ideal for Harsh Environments
Stable with a 0.1 uF Ceramic Output Capacitor
These are Pb−free Devices
Thermal Shutdown and Current Limit Protection
Available in Thermally Enhanced DFN6 3.3 x 3.3, 0.65P Package
Very High PSRR: 83/56 dB@1/100 kHz
Telecom, Industrial
Bias Power Supplies, Led Lighting
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 13:25:21
