sigma
NCS21911SN2GEVB: NCS21911SN evaluation board
NCS21911SN2GEVB: NCS21911SN EVAL BOARD
The NCS21911 evaluation board is a two layer board measuring approximately 24 mm by 23 mm. The pins of the op amp can be accessed either through surface point test points or through the header pins. The header pins are set up to have the same footprint as a DIP-14, which allows the board to be mounted on a breadboard or separate evaluation module.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 09:12:33
  • Let your Launchpad/RF2500 control music playback
  • About the communication problem between PIC16F877A and NRF24L01
  • I have a question about Enfora GSM0308 GPRS?
  • 不會用32x32 led rgb matrix
  • Regarding vias between signal lines
  • Discussion about confusing topics
