他们逼我做卧底
NCV48920PAGEVB: 600 mA/300 mA Charge Pump Buck/Boost Converter with LDO Regulator and Very Low Quiescent Current Evaluation Board
NCV48920PAGEVB: 600 mA / 300 mA Charge Pump Buck/Boost Converter with LDO Regulator with Very Low Quiescent Current Evaluation Board
The NCV48920PAEVB Evaluation Board is designed to effectively evaluate the NCV48920, which is 600 mA buck and 300 mA boost charge pump regulator with integrated very low quiescent current LDO regulator for automotive applications requiring full functionality during battery voltage drop events or reduce power losses. The NCV48920 requires very low number of external components. The Enable function can be used to disable the chip and hence to reduce quiescent current down to 1 µA. The NCV48920 contains protection functions as current limit, thermal shutdown and reverse bias current protection.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 14:32:51
