蓝猫淘气
NCP139AFCT100T2GEVB:NCP139 WLCSP-6 Evaluation Board 1V0
NCP139AFCT100T2GEVB: NCP139 WLCSP-6 Evaluation Board 1V0
The demo board supports the Bias Rail LDO regulator NCP139 in WLCSP6 1.2 x 0.8 mm package with Output Voltage 1.0 V and Bias Voltage in range from 3 V up to 5.5 V. It is a 700 mA very low dropout device equipped with NMOS pass transistor and a separate bias supply voltage rail. The device provides very stable, accurate output voltage with low noise suitable for space constrained, noise sensitive applications. In order to optimize performance for battery operated portable applications, the NCP139 features low IQ consumption. The device is available with or without active discharge feature.
Features and Applications
Input Voltage Range: VOUT to 5.5 V
Bias Voltage Range: 3 V to 5.5 V
Fixed Output Voltage device
±1% Accuracy over Temperature, 0.5% VOUT @ 25°C
Ultra-Low Dropout: 50 mV Maximum at 1 A
Very Low Bias Input Current of Typ. 35 uA
Very Low Bias Input Current in Disable Mode: Typ. 0.5 uA
Logic Level Enable Input for ON/OFF Control
Output Active Discharge Option Available
Stable with a 10 uF Ceramic Capacitor
Available in WLCSP6 1.2 mm x 0.8 mm x 0.4 mm Package
These Devices are Pb−Free, Halogen Free/BFR Free and are RoHS Compliant
Battery-powered Equipment
Smartphones, Tablets
Cameras, DVRs, STB and Camcorders
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 16:49:42
