兰博
NCV8843MNR2GEVB: Buck Regulator Demonstration Evaluation Board
The NCV8843 Demonstration Board provides a convenient way to implement and evaluate a complete practical buck regulator design. No additional components are required other than the DC input source and load. The board has an input voltage range of 5 V - 16 V and is preset for a nominal output voltage of 3.3 V. Included are SHDNB and SYNC terminals for logic on-off control of the regulator and synchronization of the internal controller to an external frequency source in place of the internal 340KHz oscillator.
Features and Applications
V2 Control Method for Uncomplicated Loop Compensation, Fast Transient Response, and Reduced Board Area
A Total of 12 Components, Including the IC, to Realize a Complete Buck Regulator
Shutdown Terminal to Disable the Output and Provide a Low Current Drain Standby Mode
Sync Terminal to Permit Controller Synchronization to an External Source
1.5 A Peak Inductor Current
Soft Start Function to Reduce Inrush Current
82% Efficiency at 1 A Load Current
Line Regulation Better Than 0.02%
Load Regulation Better Than 0.2%
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 18:35:36
