张小哥
NCV890104MWGEVB: Automotive Switching Regulator Spread Spectrum Evaluation Board
Evaluation board for the NCV890104 fixed−frequency, monolithic, Buck switching regulator intended for Automotive, battery−connected applications that must operate with up to a 36 V input supply. The regulator is suitable for systems with low noise and small form factor requirements often encountered in automotive driver information systems. The NCV890104 is capable of converting the typical 4.5 V to 18 V automotive input voltage range to outputs as low as 3.3 V at a constant switching frequency above the sensitive AM band, eliminating the need for costly filters and EMI countermeasures. A Reset pin signals when the output is in regulation, and a pin is provided to adjust the delay before the RSTB signal goes high. The NCV890104 also provides several protection features expected in Automotive power supply systems such as current limit, short circuit protection, and thermal shutdown. In addition, the high switching frequency produces low output voltage ripple even when using small inductor values and an all−ceramic output filter capacitor − forming a space−efficient switching regulator solution.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-12 09:18:36
  • Are there any WiFi modules based on AR6103 chip in China?
  • BQ30Z55 bq CHEM (Chemical ID) Configuration
  • WinCE driver development process
  • Please help me see
  • IAR reports Error[e16], interrupt vector problem
  • Summary of single chip traffic light control[2]
