他们逼我做卧底
SEC-6D6KW-OBC-TTP-GEVB: 6.6kW OBC evaluation board using totem pole topology
SEC-6D6KW-OBC-TTP-GEVB: A 6.6kW OBC evaluation board using Totem pole topology
This 6.6kW OBC evaluation board provides a reference design on the power stage of totem pole interleave PFC topology which consists of 650V N-Channel Power MOSFET SUPERFET® III (NVHL025N65S3), monolithic high- and low-side gate-driver IC (FAN7191_F085) in low-speed leg, high switching performance SiC MOSFET (NVHL060N090SC1), Isolated High Current and High Efficiency IGBT driver (NCV57000DWR2G) in high-speed leg.
With these high performance devices and totem pole topology, the system efficiency reaches 97% (typical value), and hardware protection of OCP and OVP is also provided for high system reliability. Onboard auxiliary power system is designed to supply every circuits on the board and the control board without outside DC source. Meanwhile, flexible control interfaces are available to adapt different controller boards.
Visit the On Board Charging solutions site to learn how onsemi can help you a comprehensive and advanced portfolio.
Features and Applications
3ch Interleave Totem Pole PFC
Efficiency up to 97% @Vin=220V/AC, Full Load
Onboard hardware protection of OCP and OVP
Flexible control interface for different controller boards
Input voltage – 90~260Vac
Output voltage – 1.414xVin+10V – 405Vdc
On Board Charger (OBC)
EV Charging
3-Ph AC/DC conversion
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 12:45:51
