The STR-NCP110-EVK provides an evaluation kit for the NCP110 series of 200 mA low noise and high PSRR XDFN4 packaged LDOs with fixed output voltage options from 0.6 V to 4 V. The NCP110 has an ultra-low quiescent current, making it suitable for a wide range of battery-powered devices. This evaluation kit can be used in conjunction with the Strata environment GUI, which can enable/disable the LDO as well as monitor other telemetry data on the platform, including input/output voltages, power consumption, and temperature. For more details, please refer to the Strata webpage www.onsemi.com/strata! Click to Download Strata Features and Applications Features Four different LDO families are available, each with a range of voltage options Vin ranges from 1.1V to 5.5V Maximum load ranges from 150mA to 300mA Vout ranges from 0.6V to 5.3V Automotive options available Applications DC-DC Power Supplies Battery Powered Devices Analog and RF Automotive
The STR-NCP110-EVK provides an evaluation kit for the NCP110 series of 200 mA low noise and high PSRR XDFN4 package LDOs with fixed output voltage options from 0.6 V to 4 V. With an ultra-low quiescent current, the NCP110 is suitable for various battery powered devices. This evaluation kit can be used in tandem with the Strata environment GUI which can enable/disable the LDO as well as monitor other telemetry on the platform, including input/output voltage, power dissipated, and temperature. See the Strata webpage at www.onsemi.com/strata for more details!Click to Download Strata
4 different LDO series to choose from, each with a range of voltage options
Vin range from 1.1V to 5.5V
Max load range from 150mA to 300mA
Vout range from 0.6V to 5.3V
DC-DC Power
Analog and RF
