张三叔
STR-NCV48220-LDO-CP-GEVB:Strata Enabled NCV48220 LDO Charge Pump Evaluation Board
STR-NCV48220-LDO-CP-GEVB: Strata Enabled NCV48220 LDO Charge Pump Evaluation Board
The STR-NCV48220-LDO-CP-GEVB provides an evaluation board for the NCV48220 LDO charge pump using the Strata Developer Studio. The NCV48220 is a very low quiescent current 150 mA LDO regulator with an integrated battery voltage charge pump boost converter for automotive applications with enable signal capability, current limiting, thermal shutdown and reverse bias current protection. The evaluation board is used with Strata to control the NCV48220 and monitor telemetry data such as input/output voltage, input/output current, power loss and temperature. For more details, please refer to the Strata web page www.onsemi.com/strata! Click to Download Strata Features and Applications Features Output voltage: 5 V LDO output current: up to 150 mA Very wide input voltage operating range: 3 V to 40 V Very low quiescent current: 35 uA typical Enable function (1.0 uA maximum quiescent current when disabled) Microprocessor compatible Control function: reset output AEC-Q100 Grade 1 qualified and PPAP function Protection features: current limit, thermal shutdown, and reverse bias output current Applications Stop-Start Applications Instrumentation and Cluster Infotainment
The STR-NCV48220-LDO-CP-GEVB provides an evaluation board for the NCV48220 LDO charge pump using Strata Developer Studio. The NCV48220 is a very low quiescent current 150 mA LDO regulator with an integrated battery voltage charge pump boost converter for automotive applications, enable signal functionality, current limit, thermal shutdown, and reverse bias current protection. This evaluation board is used with Strata to control the NCV48220 and monitor telemetry such as input/output voltage, input/output current, power loss, and temperature. See the Strata webpage at www.onsemi.com/strata for more details!Click to Download Strata
Output Voltage: 5 V
LDO Output Current: up to 150 mA
Very Wide Input Voltage Operation Range: from 3 V to 40 V
Very Low Quiescent Current: typ 35 uA
Enable Function (1.0 uA max quiescent current when disabled)
Microprocessor Compat ible Control Functions: Reset Output
AEC-Q100 Grade 1 Qualified and PPAP Capable
Protection Features: Current Limitation, Thermal Shutdown, and Reverse Bias Output Current
Instruments and Clusters
Infotainment
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 14:52:07
