aytwartoofyoroo
STR-NCP115-EVK: Strata-enabled NCP115 - 300mA LDO with fixed output voltage from 0.8V to 3.6V
STR-NCP115-EVK: Strata Enabled NCP115 - 300mA LDO with Fixed Output Voltage From 0.8V to 3.6V
The STR-NCP115-EVK provides an evaluation kit for the NCP115 family of 300 mA low quiescent current XDFN4 packaged LDOs with fixed output voltage options ranging from 0.8 V to 3.6 V. The low quiescent current of the device makes the NCP115 optimized for battery powered applications. This evaluation kit can be used in conjunction with the Strata environment GUI, which can enable/disable the LDO as well as monitor other telemetry data on the platform including input/output voltages, power consumption, and temperature. For more details, please refer to the Strata web page www.onsemi.com/strata! Click to Download Strata Features and Applications Features Four different LDO families are available, each with a range of voltage options Vin ranges from 1.1V to 5.5V Maximum load ranges from 150mA to 300mA Vout ranges from 0.6V to 5.3V Automotive options available Applications DC-DC Power Supplies Battery Powered Devices Analog and RF Automotive
The STR-NCP115-EVK provides an evaluation kit for the NCP115 series of 300 mA low quiescent current XDFN4 package LDOs with fixed output voltage options ranging from 0.8 V to 3.6 V. The low quiescent current of the devices make the NCP115 optimized for battery powered applications. This evaluation kit can be used in tandem with the Strata environment GUI which can enable/disable the LDO as well as monitor other telemetry on the platform, including input/output voltage, power dissipated, and temperature. See the Strata webpage at www.onsemi.com/strata for more details!Click to Download Strata
4 different LDO series to choose from, each with a range of voltage options
Vin range from 1.1V to 5.5V
Max load range from 150mA to 300mA
Vout range from 0.6V to 5.3V
DC-DC Power
Analog and RF
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 12:38:20
