aerobotics
STR-NCV8163-NCP163-EVK: Strata Enabled NCV8163/NCP163 - 250mA LDO with fixed output voltage from 1.2V to 5.3V
STR-NCV8163-NCP163-EVK: Strata Enabled NCV8163/NCP163 - 250mA LDO with Fixed Output Voltage From 1.2V to 5.3V
The STR-NCV8163-NCP163-EVK provides an evaluation kit for the NCV8163 and NCP163 series of 250 mA ultra-low noise and high PSRR XDFN4 package LDOs with available fixed output voltages of 1.2 V to 5.3 V. The NCV8163 and NCP163 are designed to meet requirements for sensitive RF and analog circuits with typical applications in various battery powered devices. The NCV8163 is rated for automotive and industrial applications. This evaluation kit can be used in tandem with the Strata environment GUI which can enable/disable the LDO as well as monitor other telemetry on the platform, including input/output voltage, power dissipated, and temperature. See the Strata webpage at www.onsemi.com/strata for more details!Click to Download Strata
Features and Applications
4 different LDO series to choose from, each with a range of voltage options
Vin range from 1.1V to 5.5V
Max load range from 150mA to 300mA
Vout range from 0.6V to 5.3V
Automotive options available
DC-DC Power
Battery Powered Devices
Analog and RF
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 13:55:26
  • ST-linkclone (STM8 part), about licensing
  • A program can either not be synthesized or it can not be simulated.
  • VCOM pin of TFT LCD
  • DM642 DSP/BIOS content configuration
  • What is the difference between system power and device power?
  • Brief Analysis of Chassis of Intelligent Model Car
