JFET
Wireless Home Automation (Control and Monitoring) using Nextion HMI Display_MainBoard
2-layer PCB 56.6 x 83.1 mm FR-4, 1.6 mm, 1, with wire spray tin, green solder mask, white silk screen; Today, home automation has become a hot topic among electronic enthusiasts and even the general public. People are busy with life challenges, so electronic devices should take care of the home! Most of these devices require Internet or Wi-Fi for connectivity or do not provide a user-friendly GUI, but I decided to design a standalone wireless monitoring/control unit that can be adjusted using graphics and a touch-controlled LCD display. The device consists of a panel and a mainboard and uses a 315MHz (or 433MHz) ASK transceiver for communication. The panel side is equipped with a high-quality 4.3-inch capacitive touch Nextion display. Users can monitor real-time temperature values ​​and define operating thresholds (to activate/deactivate heaters or coolers), humidity (to activate/deactivate humidifiers or dehumidifiers) and ambient light (to turn lights on/off). The main board is equipped with 4 relays to activate/deactivate the above mentioned loads. To design the schematic and PCB, I used Altium Designer 23. The fast component search engine (octopart) allows me to quickly consider component information and generate BOM. To get a high quality fabricated board, I send the Gerber files to PCBWay. I use the Arduino IDE to write the MCU code, so it's very easy to follow and understand. Designing a GUI using the Nextion tool was a pleasant experience, one that I will definitely follow on similar projects in the future.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-07-08 19:21:18
