bjhsUX0cgU
PCB IC card (tested)
PCB card, you can freely modify the picture. Use PCB as the coil and thicken the coil. There is a ruler on the PCB to facilitate measuring the length. You only need a 13.5MHz IC card chip to weld. There is nothing to introduce. No LED is added. lamp, to ensure maximum stability and facilitate welding.
This project has been tested, and there have been no problems so far.
Suggestions:
1. It is recommended to use low-temperature solder paste and weld with the heating table. The chip must be clamped during welding, otherwise the chip will One solder joint runs
2. If you use a lighter to heat from the back, you need to control the time. Failure to control the temperature may burn the chip.
3. There is nothing to say ←_← This is also relatively simple. Generally, lead-free solder paste can be used for soldering. If the solder joint is not perfect, you can heat it again and the solder joint will be full and round.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 04:20:26
